Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Should have said APM P2 sorry my mistake.
I got you now but it really doesn't seem like it in the text...
We are referring to APM Planner 2. Mac OS GCS
I had the same problem with APM2. Just reload with the latest beta APM Planner and it should work fine. It is an APM planner issue that has been addressed.
RB
Yes your right that corrected that. Great!! Thanks...
But..... my teensy lua script no longer works. Bummer.... very handy. No GCS needed. Not sure where to look to address that problem. I did set the SERIAL2_PROTOCOL to "3" as suggested. The X8R receiver is getting telemetry just no data from the pixhawk it seems.
Now if I get DCM bad heading I won't know... sweet!! Fixed!! LOL
Excellent thank you I will try that.
went back to 3.2 seems fine. I highly suspect it's APM2... guess I'll post over there and see if Bill has any idea's.
I remembered having problems with the teensy mavlink and went back in to check on my machines. I ended up setting SERIAL_2 protocol to 2 instead of 3 on all three of my copters and they continue to communicate to the transmitter through all the 3.3 progression. This was just trial and error on my part, not even an educated guess but it works.
Cheers,
RB
My quad has been running 3.3 rc4 for probably 2-3 hours with no real issues, including no 'bad gyro health' warning. Yesterday I decided to reset the parameters and re-calibrate everything because I had made a few changes and wanted to see if Auto Tune produced different results.
Wow, all heck seems to have broke loose. I installed a new GPS, but it had errors before doing so. I'm not sure if this one was there before the new GPS:
There was another EKF error "Error EKF POS VERT AGL" and now I get 'bad gyro health' constantly.
I think it may be time to wipe the sd card and start over, but odd it had been running so well.
The external compass on this new GPS has high offset on x (not used to seeing >75) and internal has been high since installing the AUAV-X2. I'm thinking it's picking up noise from the power wires underneath, not sure yet?
The "Error EKF PRED.." thing is a mission planner issue related to how it's displaying new information from the EKF. I hope that will get fixed shortly but I don't think it requires a change to arducopter.
The "bad gyro health" issue has been resolved in master and will go out with -rc5 which should be out soon. It's a timing issue so it can come and go.. it could be that the new GPS is causing jitter in the main loop which would lead to more of these bad gyro health messages but I'd need to see a dataflash log.
