Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
@ Dev team,
RC Inputs. Is there away to using channels RC13-16? The Taranis (and many others) has loads of switches, especially with the 6 position mod and I would like to add just a couple more switch options.
Cheers, Mike
Mike,
There's no way to use channels above 12 I'm afraid... but with this new release we've just expanded the aux switches so they can be assigned to ch7~ch12 (instead of just ch7/ch8). Do we really need more than 6 auxiliary switches? At some point I think we should instead make all these aux features available through the GCS which has a much richer interface and doesn't require any set-up by the user.
Did some more testing with Altitude and let the copter sit a while outside. Then flew for a while and landed. Altitude was close to zero when landed. Altitude does not reset until the power is cycled. Variance seems to be caused by temperature changes.
https://youtu.be/ckY_XuoxMEU
Paul,
Your work is brilliant,
Comparing to the "Rolling Spider" from Parrot, the performance is almost the same level above rich-textured ground.
However, the roll spider seems to be able to catch more features, and it flies well above ceramic tiles. For PX4FLOW textured cloth must be placed on the tiles.
Could the frame rate of PX4FLOW be slowed down to catch more features(like 128*128) to make it competitive to the commercial solution?
I do not have the new DJI products like INSPIRE1 and Phantom3, there are rumors about DJI cooperated with ETH on the vision navigation system, have you ever tested their solution?
Zhang
A couple of test with 3.3 and all looks good. Landing and RTL set down nicely and even shuts down the motor without issue.
Did notice that when using a GCS the copter does not sound a tone when changing flight modes, only when using the RC transmitter. Auto mode with saved waypoints and guided work well.
Still have a little issue with Altitude though. On the ground with GCS take off it was at 1.2 meters before it left the ground.
Did a 5 minute flight and the Altitude was off by 5 or 6 meters when it landed. Usually when landed shows negative altitude.
Need to do more testing.
MOUNT_TYPE parameter name actually MNT_TYPE; but it works for me (servos)
I have a new Iris + and I installed the Beta 3.3 RC3 and I am now not getting the FrSky Telem out to my Radio. I verified the settings and all are correct. I re-installed 3.2.1 and it came back. I just wanted to report this and see if it happened to anyone else that might have the fix.
Joe
I had the same thing. In MP, go into the parameters. Change the value for SERIAL2_PROTOCOL to 3. Simple fix that a couple of the devs pointed me to.
Roger that.
short report:
AC 3.3 RC3, 3DR Quadcopter with Pixhawk and LidarLite rangefinder installed (via PWM),
rangefinder works fine (according to sonarrange in the status window),
but if I try to arm the copter it refuses - I get the message: PreArm check range finder
the sensor is set up according to the wiki, height is about 10 cm above ground, value (on the ground) displayed in status window is 0.34
I have set RNGFND_MIN_CM to 20 and 40 - arming doesn't work in both cases
