Crius ALL IN ONE PRO Flight Controller v1.0
I see rctimer is selling these for $63, and it looks to have pretty similar hardware spec to the APM2. It says that it supports Multiwii and MegapirateNG code.
After my oilpan died the other day, this looks like a worthy secondary board to have a go with.
Has anyone got/tried one?
Would I be correct in thinking that it should be possible to get telemetry data output in the S0/FTDI port so that a minimOSD could be connected? The GPS I used for my APM1 should also plug into the I2C port too right?
http://rctimer.com/index.php?gOo=goods_details.dwt&goodsid=765&productname=
Update
All in one pro v2 is now available from RCtimer and Unmanned tech
All in one Pro setup
  • hi can someone here explain to me how to used this board.. since i really new in this UAV system~~ i want to know hoe to uesd for each port.. if possible if u have datasheet for this u can email to me at dhirah25@gmail.com~~ really want to know more about it~~ thanks a lot!!
  • Oh ya, if you get one of these......be really careful with the usb port as you can rip it right off the board. Been there done that.
    Its pads are to thin to hold it to the board and the designer has admitted it needs revised. Says next revision will have beefed up pads.
    I moved to using the ftdi port cause I am like a gorilla with fragile things :)
    Ken
  • I have one, in process of PID tuning for 550 quad for megapirate. Seems like people are happy - most bugs are sorted. Some nice flying videos. Hard to beat for the money. Some issues with GPS but is sorted for the (RC Timer) UBLOX CNO6 and I think others are working but some issues. Documentation is hard to come by but this forum is very good and everything you need is there. You need to be aware of multiwii and megapirate thread running side by side - can be confusing. I have a word file with relevant links and images that follows the thread from the beginning for MPng - PM me if you want it.
