  • so this was the answer i guest?
    quote from Micheal Thomas above;
    "If there is a high-wind, or more complex manoeurvres such as landing then airspeed sensor helps a lot."
  • It's not technically needed - I have flown in auto without an airspeed sensor. If there is enough stall margin as you say you won't have too many issues, and the APM can rely on ground speed from the GPS. If there is a high-wind, or more complex manoeurvres such as landing then airspeed sensor helps a lot.
  • For me, I am an engineer who is doing research with UAV  technologies. So, yes you don't need one to perform the functions that you are talking about, but eventually this information might be useful. I will probably have to use this information to somehow improve on the fixed wing UAV control systems. So although it is not specifically needed for your application, some people could find it useful, even if they just look at the speeds to see if they match up with other flight data. :-)
DIY Robocars via Twitter
RT @a1k0n: Starting on a rough guess of the track centerline as an SVG. Then I use svgpathtools to generate equally-spaced points w/ direct…
5 hours ago
RT @a1k0n: This rules. My existing code isn't going to work *at all* -- the track planner and precomputed map are out. However, it forces m…
5 hours ago
RT @chr1sa: Our new @DIYRobocars track at @circuitlaunch is fiendishly hard & crashtastic fun. Combines hairpin curves with an intersection…
7 hours ago
The May @donkey_car newsletter is out, with news about release 4.2, next events and more https://donkeycar.substack.com/p/may-newsletter
yesterday
yesterday
yesterday
RT @breadcentric: Bingo card for AWS DeepRacer Finale, starting in 10 minutes on https://www.twitch.tv/aws ! #AWSDeepRacer #DeepRacer #Machin…
yesterday
RT @NVIDIAEmbedded: It's #NanoFriday - the RB-0 uses the same suspension concept as #NASA's newer differential-bar rovers. This educational…
yesterday
RT @chr1sa: On May 22, we're returning to in-person AI @DIYRobocar racing at @circuitlaunch. The Amazon @awscloud DeepRacer team will be pr…
Wednesday
RT @breadcentric: On my CV: Hobbies: Training bananas to race on tracks #AWSDeepRacer #DeepRacer https://t.co/MKe14hNyux
Wednesday
RT @breadcentric: See how the April AWS DeepRacer races have ended and a couple bits of news: https://blog.deepracing.io/2021/05/09/aws-deepracer-league-2021-update-11-end-of-april-special/ #AWSDeepRacer #Machin…
Monday
RT @sunilmallya: Representation Learning +Instance Transfer to learn new reward functions along with advantage based filtering of new exper…
May 9
Apr 27
Apr 27
RT @f1tenth: Sliding (autonomously) into the weekend like ... 🤖😎 #f1tenth #robots #AutonomousVehicles @OpenRoboticsOrg @NVIDIAEmbedded @Aut…
Apr 25
RT @chr1sa: One of the problems with autonomous car racing is that watching software drive is not a very exciting spectator sport. To help…
Apr 25
