DIY ESC/engine/propeller tester
I made engine tester based on arduino. I would like to ask you, if someone/something does exists ? I found only too expensive commercial project: https://www.rcbenchmark.com/.
My cost only few $$ and I dont know if Im missing something. Here is what Im doing:
  • measure voltage (rezistor divider + analog input on arduino, resolution ~30mV) and current
(ACS712 20A, resolution 40mA) on ESC input, current measurement is tricky - the value is really unstable so Im doing averiging from 300 values but still... it needs improvement [$2]
  • measure thrust with weight sensor: 5KG FZ0967 + HX711 [$4.5]
  • measure vibration with MPU 6050 [$3.3]
So I can calculate:
  • power in Wats
  • efficiency in g/W
I used Arduino UNO copy with LCD + buttons shield [maybe $10 ?] + extra potentiometer. There are two modes:
  • manual - I can control input PWM with potentiometer and I can see all measured values on display and in serial monitor when arduino is connected to PC, one measure takes ~2seconds
  • automatic - PWM is going automatic from 0% to 100% with 5%step, measured values are printed to serial monitor so then it is easy copy all values to excel and make some charts..
My motivation is compare ESCs, motors, propellers to get best combination. The tool is mounted on my table during measurement so there is a lot of space around. I know it is not exatly as during real flight but still, it is good to compare.
Are you interested in or am I doing something what exist or is useless ?
btw sorry for my english..
EDIT:
video on the youtube
EDIT2:
project website: http://diy.ivosch.cz/buzz-drone-engine-tester/
  • hi, sorry for the delay, I'm working on my 3rd hexacopter, I prepared a brief instructions how to build my tester called "Buzz" :)
    here it is: http://diy.ivosch.cz/buzz-drone-engine-tester/
  • Here is my source as promised: https://github.com/AndKe/ThrustMeter   Please feel free to improve and share.
    https://www.youtube.com/watch?v=S2vaC5SftQc
    AndKe/ThrustMeter
    An thrustmeter for measuring thrust, power, efficiency of RC motors. - AndKe/ThrustMeter
  • Good Job Ivosch! I have done this manually with eagle tree logger and scales for years and now it's time to automate it like you did. Expecially the auto excel data export is really usefull! Will you share the source?
  • I created a video how works automatic mode: youtube.
  • That is true, every ESC has different throttle calibration and behavior. But to compare ESC's actually I don't need RPM. What is important to me is max thrust and efficiency. To compare efficiency is good chart efficiency vs thrust which I can create. When you use same propeller then thrust corresponds to RPM.
    I will try to prepare simple tutorial "how to build" with source codes in the next week.
  • To get usful comparison values you really need RPM mesurments
    if you compare ESC's with same motor and same prop you can get verry different values at the same input pwm
  • My version will be on github next week.
  • MR60
    this is a great diy work!
    would you share a build tutorial and arduino code?
  • I am using power module, and sample +average it a lot, used ACS758 hall sensor too, needs a bit finer filtering.
    As long you have a power source, (lab psu or battery), then current measuring device, then some 15cm cable length before esc (with sufficient capacitors, then the current is smoother.
  • Nice job, it looks similar. How do you measure current ? For me it is hard to get effective value when ESC is switching 3 phases.
    I want to measure vibrations to see how propellers are balanced. Because of this the motor has to be mounted on the real arm... to get real behaviour.
DIY Robocars via Twitter
RT @chr1sa: Just a week to go before our next @DIYRobocars race at @circuitlaunch, complete with famous Brazilian BBQ. It's free, fun for k…
Saturday
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
Nov 28
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Nov 26
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Nov 25
@gclue_akira CC @NVIDIAEmbedded
Nov 23
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9
RT @JoeSpeeds: Sat Nov 6 Virtual DonkeyCar (and other cars, too) Race. So bring any car? @diyrobocars @IndyAChallenge https://t.co/nZQTff5…
Oct 31
RT @JoeSpeeds: @chr1sa awesomely scary to see in person as our $1M robot almost clipped the walls as it spun at 140mph. But it was also awe…
Oct 29
RT @chr1sa: Hey, @a1k0n's amazing "localize by the ceiling lights" @diyrobocars made @hackaday! It's consistently been the fastest in our…
Oct 25
RT @IMS: It’s only fitting that @BostonDynamics Spot is waving the green flag for today’s @IndyAChallenge! Watch LIVE 👉 https://t.co/NtKnO…
Oct 23
RT @IndyAChallenge: Congratulations to @TU_Muenchen the winners of the historic @IndyAChallenge and $1M. The first autonomous racecar comp…
Oct 23
RT @JoeSpeeds: 🏎@TU_Muenchen #ROS 2 @EclipseCyclone #DDS #Zenoh 137mph. Saturday 10am EDT @IndyAChallenge @Twitch http://indyautonomouschallenge.com/stream
Oct 23
