DIY or COTS VTOL Surveying?
Simple question, but coming from my background, I have the passion to make my own, I'm just not sure if its feasible in this situation.  I know a little about the ardu pilot, I am a self taught EE, with some Python, C, and CPP skills.  While I love making things, I'm concerned this is WAY outside of my abilities just because of my lack of knowledge of the commercial drone platforms.  I work better on lists, so this is my ramblings:
Musts:
Self return to charging pad
remote operation via PC
remote video on same PC (std. IR, FLIR, etc)
FULL OSD on the PC
20-30 minutes min flight time
GPS
Wants:
programmable routes
ability to track an object
  • Thank you for the awesome information! Greetings from Germany
  • This is a very cool project. You're doing a similar project for your coursework. Using the service https://writix.co.uk/do-my-coursework I am writing a paper on how to create such a project myself and I am describing a similar experience. Thanks for giving me a couple of great ideas in the discussion to use in my coursework.
    Do My Coursework
    I need to ✍do my coursework✍ strikes with pressing deadline and you wish to let someone else write my coursework? ☝Solution is to let professional he…
  • awesome, simple enough, thank you!!!
  • Alright, you could definitely do that with Arducopter and a DIY drone. Of course you would have to program the part where it gets tripped by the motion detector and all that, but flying a perimeter or pre-determined search pattern is definitely doable.
  • Thanks for the information.  I dont have any software, as the last drones I worked with arent exactly available for the civilian world.  All I really want, end of day, is to patrol my property, which I dont live at, and when a trip sensor detects motion, the UAV can take flight, head to the location, take video, return and upload and/or message me
  • You can definitely do all of that with a Pixhawk or a Navio2+Raspberry Pi running Arducopter. Use Mission Planner on your PC (or similar software on a mobile device such as a tablet) for your ground station. You can do waypointing and pre-programmed routes, etc.
    Video: Run either an FPV camera or an Action Cam or even larger camera with HDMI output to a video TX and hook a video RX to your PC or mobile tablet / phone or even FPV goggles.
    For OSD you can use the Minam OSD or Pitlab.
    Flight time is of course dependent on many variables, but 20 - 30 should be doable if you're all up weight is realistic for the batteries you're using.
    I think the real question would be: What are the commercial UAVs going for that do what you want, and is it realistic to make your own instead? From what I can read, it seems the software for mapping / surveying is the most complex part. Do you already have a software package in mind for that?
    If you need super accurate (down to CM stuff) results, you will probably need to invest in some kind of RTK gear. I know Emlid and others make them. Maybe someone with more knowledge of those systems will add their advice.
DIY Robocars via Twitter
RT @a1k0n: Starting on a rough guess of the track centerline as an SVG. Then I use svgpathtools to generate equally-spaced points w/ direct…
Saturday
RT @a1k0n: This rules. My existing code isn't going to work *at all* -- the track planner and precomputed map are out. However, it forces m…
Saturday
RT @chr1sa: Our new @DIYRobocars track at @circuitlaunch is fiendishly hard & crashtastic fun. Combines hairpin curves with an intersection…
Saturday
The May @donkey_car newsletter is out, with news about release 4.2, next events and more https://donkeycar.substack.com/p/may-newsletter
Saturday
Friday
Friday
RT @breadcentric: Bingo card for AWS DeepRacer Finale, starting in 10 minutes on https://www.twitch.tv/aws ! #AWSDeepRacer #DeepRacer #Machin…
Friday
RT @NVIDIAEmbedded: It's #NanoFriday - the RB-0 uses the same suspension concept as #NASA's newer differential-bar rovers. This educational…
Friday
RT @chr1sa: On May 22, we're returning to in-person AI @DIYRobocar racing at @circuitlaunch. The Amazon @awscloud DeepRacer team will be pr…
Wednesday
RT @breadcentric: On my CV: Hobbies: Training bananas to race on tracks #AWSDeepRacer #DeepRacer https://t.co/MKe14hNyux
Wednesday
RT @breadcentric: See how the April AWS DeepRacer races have ended and a couple bits of news: https://blog.deepracing.io/2021/05/09/aws-deepracer-league-2021-update-11-end-of-april-special/ #AWSDeepRacer #Machin…
May 10
RT @sunilmallya: Representation Learning +Instance Transfer to learn new reward functions along with advantage based filtering of new exper…
May 9
Apr 27
Apr 27
RT @f1tenth: Sliding (autonomously) into the weekend like ... 🤖😎 #f1tenth #robots #AutonomousVehicles @OpenRoboticsOrg @NVIDIAEmbedded @Aut…
Apr 25
RT @chr1sa: One of the problems with autonomous car racing is that watching software drive is not a very exciting spectator sport. To help…
Apr 25
