Do you threadlock your prop nuts?
I'm new to the 3DR multirotors and their shaft setups, but I've already lost 2 props due to prop nuts becoming unfastened in flight.  Neither led to a crash (thanks to the Y6's redundancy), but after the last one I was unable to find the prop nut.
I crank them down as much as possible using a small allen key for leverage, but can only get so tight because it's tough to get a grip on a round motor.  Do you guys use threadlock to keep your prop nuts on?
  • I love how the usefull information come months after it was needed
    • I find old threads VERY useful. It is called "Search"  When one knows how to do searches with well chosen key words answers are found in mere seconds.
  • I use "nyloc" nuts and without threadlock of course. I'm also changing nuts to new after 4-5 times opening. This habit comes from working with fullsize airplanes and copters....
    Regards
    Jani
      Another point to remember about thread-loc, is that its dangerous to use with glass filled nylon parts.
      I learnt the hard way when I noticed dozens of spider cracks around every screw on my helicopter frame after using Loctite.
  • You said..
    Are your prop nuts collet type or the newer later style that with the threaded stud above the prop hub like THIS ?
    If collet type, there are some precautions to use. If the later style, try holding the prob hub while tightening rather than the motor housing...threadlocker won't hurt either.
    -=Doug
  • Yes. Learned the hard way. Sometimes you just forget to check them before launching.
  • unlike andrew I do recommend theadlock, then again I have only flown fixed wing. I have also had no issue getting the nut off afterwards or if you still don't like the idea of  a CA a nylock nut will be the next best option
  • No but I check them every couple of flights as part of my preflight. Use regular hex nuts instead of the pretty cone shaped nuts if your concerned.
    • I now thread lock using the Blue. With wood props I still have to double check in case they swell or shrink. Blue allows you to be able to remove later.
