Hi all,
My question: does the arducopter control laws ignore the onboard magnetometer when the external compass is initialized on the Pixhawk/APM. Furthermore, is the external compass MAG or MAG2 in the datalog?
I'm having some yaw issues on a large quad and trying to figure out the root cause. I am using the 3DR uBlox GPS with Compass Kit on a mast approximately 6 inches above my the Pixhawk. I have 3.1.2 firmware loaded on my Pixhawk.
When analyzing the datalog, I noticed that both MAG and MAG2 are being recorded. I assume that because I am using the external compass, the arducopter control laws utilize the data from the external compass rather than the magnetometer on board the Pixhawk. Is this true?
I've attached a MATLAB plot for further reference. There is a possibility that the root cause if purely bad tuning, although I'm trying to eliminate as many variables as possible.
Thanks,
Tony
  • At this point in time, the internal magnetometer is just logged and not used in the flight controls. I believe there are future plans to have the APM switch to the internal magnetometer if the external one fails (i.e have it as a backup sensor).
    Yaw issues can be due to the magnetometer not being calibrated.
    • Thank you Stephen, I'll report back if i figure it out. First thing I'll do is recalibrate the mag.
