I just finished the initial build of my very first arducopter (the Y6 DIY kit)... however, I am unable to get it to arm!
I do not yet have the GPS/Compass as it is backordered, but everything else is installed.
I have successfully calibrated the ESCs, I can see the control sticks input in the Mission Planner and have configured the Frame Type, Accel, and Radio.  However, I cannot get the APM to arm in order to start testing my motor directions.  All the motors turn at the end of ESC calibration.
Any advise?
**EDIT: I  can successfully use the "ARM/DISARM" button in the MP (via the telemetry radio) but the APM disarms itself after several seconds.  I was able to use the short periods of forced arming to get my motors wired correctly... but I still can't arm normally or keep it armed artificially.
  • Hell,Richard!! I 've disabled all parameters for the failsafe in full parameter or advance para [  forgot now,]  all numbers that associate with failsafe to zero, but still won't arm APM2.6 board has solid Blue LED and RED flashing [unarmed ] and solid green LED at power port and also on GPS board
    has solid RED and flashing Blue it m eans GPS is OK. right?
    P.S this is APM2.6 and I have GPS only and waiting for compass. I have 2.5 bought from 3drobotics but it will not working right now..Thank you very much.
  • Hello, congrats!!! but for me I have used only GPS and no compass also [ waiting for compass] but after disable failsafe  parameters [ all to zero no.] still won't arm , Blue LED on APM board is solid but the red is flashing
    [ unarmed] and on GPS unit solid red and flashing Blu LED. it means GPS is OK .right? My questions to you is how you did it?? I bough this APM2.6 because my Ardupilot 2.5 mega from 3drobotics is kaputt.So I've decided to buy this 2.6 for fun while tryin to fixed 2.5 but forgot to buy compass because 2.5 has compass built in.So if it can arm and I will have fun with it w/o compass for the time being..Please let me know how did you do to make it arm for you. Thanks alot.
  • Do we need to have a gps and a compass or is this one and the same?
    I have a Ublox gps, does it have a compass built in?
  • Just an FYI, you can arm without the GPS installed and leave the failsafes on.
    I didn't try with out the compass though.
  • Disable 'Pre-Arm' check.
    Go to Adv. Parameters list,
    Set 'Arming_check' to zero.
    Maybe you could just disable the compass from 'Hardware options'
  • T3
    You may need to disable the fail safe parameter. It won't let you arm without a GPS.
    You can also test prop rotation via the command line.
DIY Robocars via Twitter
May 15
May 14
May 13
May 13
May 11
May 8
May 8
RT @SmallpixelCar: Test my car. RTK GPS worked great. Thanks @emlid for their support. https://t.co/EkQ6qmjmWR
May 8
DIY Drones via Twitter
RT @chr1sa: @kane That's @diydrones circa 2009. Still have a box of those Canon cameras that we used to strap into planes, just like this.…
May 3
RT @chr1sa: Our next @diyrobocars race is going to be outside at a real RC racetrack in Fremont on May 28. Fully autonomous racing, head-to…
Apr 30
RT @f1tenth: Our Spring 2022 F1TENTH course @PennEngineers is coming to an end with a head-to-head race as a big finale. So proud of our st…
Apr 26
RT @DanielChiaJH: I wrote a thing! Throughout the development of my @diyrobocars car I've been using @foxglovedev Studio to visualize and d…
Apr 23
RT @SmallpixelCar: My new car for high speed. Low body, everything ( @NVIDIAEmbedded Jetson Xavier NX, @emlid RTK GPS, IMC) under the deck…
Apr 23
Apr 21
RT @f1tenth: F1TENTH Race training setup @PennEngineers for our upcoming ICRA2022 @ieee_ras_icra competition. @OpenRoboticsOrg @IndyAChalle…
Apr 21
RT @fatcatFABLAB: Proud to be hosting a restarted DIY Robocars NYC Meetup April 26. Come by if you want to talk about and race self-driving…
Apr 17
