Drone acting weird
Hello Everyone,
Ok so I build a new drone in the "x" config and it flies real well.  I am able to have it hover in one place and fly it around in a very small space in my back yard, I end up bumping it into a plastic can right as I turn off power to land.  No biggie just broke a prop.
I replace prop and the next day take it to the park to fly.  It starts to do this weird stuff at the park.  It will fly level then you can hear one or two motors speed up and it does this weird "dip" then recovers, dips like it is going to flip over then recovers.
http://youtu.be/-z6qtG7GDGo
So I switched batteries and double checked the ESC connections and it seems to fly better but their is still this "hint" of this dip then recover issue.
Next day I recharge the batteries and go into back yard and it seems to be right back to trying to crash it self.
What is happening?
  • Ensure that your new props are balanced and the motors must not be generating any vibrations
  • Also check all your esc/bullet connections   You may have bent a motor shaft, you can test this by moving a motor around and see if the problem follows.
  • calibrate your ESCs again... and ensure the motors are spinning freely... reload the arducopter firmware again to defaults and re do the parameters... it should solve the problem. Also, when you arm the ESCs ensure that the copter is sitting on a leveled platform. Take of in the stabalize mode only and then try any other mode.
DIY Robocars via Twitter
RT @chr1sa: On May 22, we're returning to in-person AI @DIYRobocar racing at @circuitlaunch. The Amazon @awscloud DeepRacer team will be pr…
yesterday
RT @breadcentric: On my CV: Hobbies: Training bananas to race on tracks #AWSDeepRacer #DeepRacer https://t.co/MKe14hNyux
yesterday
RT @breadcentric: See how the April AWS DeepRacer races have ended and a couple bits of news: https://blog.deepracing.io/2021/05/09/aws-deepracer-league-2021-update-11-end-of-april-special/ #AWSDeepRacer #Machin…
Monday
RT @sunilmallya: Representation Learning +Instance Transfer to learn new reward functions along with advantage based filtering of new exper…
Monday
Apr 27
Apr 27
RT @f1tenth: Sliding (autonomously) into the weekend like ... 🤖😎 #f1tenth #robots #AutonomousVehicles @OpenRoboticsOrg @NVIDIAEmbedded @Aut…
Apr 25
RT @chr1sa: One of the problems with autonomous car racing is that watching software drive is not a very exciting spectator sport. To help…
Apr 25
RT @SmallpixelCar: Replaced AGX Xavier with @NVIDIAEmbedded Jetson Xavier NX. Now both cars look fast and clean https://t.co/jlcoY2EjZf
Apr 25
RT @chr1sa: Yesterday we had a record number of competitors (36) in our monthly @DIYRobocars virtual autonomous car race. We kept it going…
Apr 25
Apr 16
DIY Drones via Twitter
RT @chr1sa: After more than a year of only virtual races, @DIYRobocars returns to the newly renovated @circuitlaunch on May 22 for the resu…
Apr 11
RT @DAVGtech: And now available with LiDAR 🔥 https://twitter.com/Heavy02011/status/1381137016381964293
Apr 11
RT @Heavy02011: #VirtualRaceLeague: @DIYRobocars Race #9 - #ParkingLotNerds #thunderhillracetrack, CA Join us for the next race April 24th,…
Apr 11
RT @DWalmroth: Weather's finally cooperating, looking forward to racing 1:10 scale autonomous cars outdoors again! @diyrobocars, @NVIDIAEm…
Apr 7
RT @AIDRI_: I finally succeeded in optimizing the trajectory and speed of a car on a #racetrack. Next step: implement a 2d controller and…
Apr 7
