0 Dumb question: motor mount LEDs Posted by Christopher Cooper on June 18, 2011 at 8:48pm Sorry if this is a dumb question, but what are the motor mount LEDs for? I see references to these in the code, but no actual documentation.Chris You need to be a member of diydrones to add comments! Join diydrones Tags: led, motor, mount Email me when people reply – Follow
Check this out by Ante Vukorepa, its originaly for the pirates code but I believe its now valid for AC2.
it gives you a front flashing LED and three solids.
you can mount LEDs at the motor mounts
there are some outputs on the APM which makes them flash in a defined pattern
