ESC Getting hot? Ideas?
I noticed my copter tilting backwards, while it's leveled correcty. So it needs correcting all the time while flying. But now I have an idea what's causing the problem. The ESC that's controlling the motor on the back is getting more hot than the others during normal load, the difference is significant. There is someting wrong there... The motor doest NOT get hot.
My setup can be seen as 'standard'.
So faulty ESC, any ideas?
    In a twin motor plane of mine that's had some 189 flights, I use both BEC's from the ESC's in parallel for 5v power for the Rx so the current is being shared. In my application the current draw is relatively low (4 servo's and 3 servoless retracts) however I have had no problems whatsoever running the two BEC's in parallel.
    Could the 4 BEC's in a quad be shared?
  • I have the same issue that the one ESC BEC supplying power to the APM gets quite hot. Its nearly hot enough you cant hold it and I haven't even fully loaded it up yet. Is there a better way to supply power to the APM  without adding another power supply/battery from the existing battery? My battery is 4s 3300mH
  • I noticed that the ESC driving the APM gets hotter in my setup.
    Now I run the APM on a separate powersupply.
  • My attitude is buy higher amp than needed and configure to limit engine amps so that the engine never gets near the top amps draw of the engine controller.
    Bearings going bad? Do you have a watt meter to check? More friction = more current = hot ESC...
Mike Whitney liked Mike Whitney's profile
Jul 19
DIY Robocars via Twitter
Jul 2
Jun 26
Abdulatif Tlaib liked Ryan's profile
Jun 24
RT @SmallpixelCar: First time at @wsraceways. After tuning @HokuyoUsa lidar signal and camera sensor on @NVIDIAEmbedded, my car was able to…
Jun 20
RT @breadcentric: The handy bit about racing with self-driving cars is that one can type while the car is racing. Report from #AWSDeepRacer…
Jun 18
RT @chr1sa: Our Bay Area @DIYRobocars meetup is now at 2,700 members. Next in-person events (in Oakland) are training day on July 17 and…
Jun 18
Videos from the ICRA autonomous racing workshop are now available: https://linklab-uva.github.io/icra-autonomous-racing/
Jun 10
RT @SmallpixelCar: Prepared race track for Warm Spring Raceways @wsraceways and looking forward to test my new car at RAMS RC @ramsaicar fa…
Jun 6
RT @f1tenth: Trying out some nasty blocking maneuvers 🏎️🤖 #f1tenth #autonomousracing https://t.co/nMTstsaogM
Jun 5
May 27
RT @araffin2: I will talk this Saturday from 18:00 to 19:00 Paris time for the @diyrobocars community about learning to race in hours using…
May 27
RT @a1k0n: Luckily the infeasible hairpin problem was easily reproducible in simulation and I could test the fix before bringing the car ba…
May 26
RT @a1k0n: Another problem was that I was over-constraining the car's allowed accelerations, so it didn't think it could turn as tight as i…
May 26
RT @a1k0n: Breaking the map up into two halves worked, but I had to be more careful about separating the inner track from outer. There's se…
May 26
RT @a1k0n: Here's a datalog for my fastest lap of the day. Lap timer is tiny window lower-left. https://t.co/myrlWWrKUY
May 26
