ESC placement / power wiring
Hello I came up with this way of installing the ESCs that I found makes for a neat tucking away of cables.  Doing them one by one I noticed that by having the cabling take a natural route around the power board my routing ended up so that while an ESC is located underneath the power plate on one side, its control cable connect to the power board control outlet on the opposite side. And as it happens so does the motor cables. So a motor will correspond to the power board speed control connector on the same side as that motor. Should it turn out sides needs to be swapped around to match the APM sw then it´s simply a matter of swapping the control leads around and these have plenty of length.  I connect the input power cable of each ESC to the socket located 90 degrees clockwise ahead of the ESC. Which power socket you chose does not matter from a functional point of view since they are all interconnected. Use the one that makes for nice cable routing as I did here. I used four straps in total to hold wiring neatly.  My control cable wiring is wrong in the photo, but I´ll swap them around.
Per request, here are photos with the dome and platforms attached. I have some more electronics to mount before takeoff, but you get a sense of it.
  • I too would like to know if there are any heat issues with this setup, keep us posted!
  • if you want to get a magneto, keep an eye on the readings
    the way you routed the cables could cause a big magnetic field when powering up the motors
  • This is a pretty neat solution.. much better then the "strap the ESC" to the arm one
  • I like how the connections from the ESC to the power distribution board are easy to access. This will make it MUCH easier to disconnect the ESC's when programming and configuring the board!
    If you can, could you post a picture of the dome attached when you have that done. I would like to see how it looks as an almost finish product.
DIY Robocars via Twitter
RT @breadcentric: See how the April AWS DeepRacer races have ended and a couple bits of news: https://blog.deepracing.io/2021/05/09/aws-deepracer-league-2021-update-11-end-of-april-special/ #AWSDeepRacer #Machin…
yesterday
RT @sunilmallya: Representation Learning +Instance Transfer to learn new reward functions along with advantage based filtering of new exper…
yesterday
Apr 27
Apr 27
RT @f1tenth: Sliding (autonomously) into the weekend like ... 🤖😎 #f1tenth #robots #AutonomousVehicles @OpenRoboticsOrg @NVIDIAEmbedded @Aut…
Apr 25
RT @chr1sa: One of the problems with autonomous car racing is that watching software drive is not a very exciting spectator sport. To help…
Apr 25
RT @SmallpixelCar: Replaced AGX Xavier with @NVIDIAEmbedded Jetson Xavier NX. Now both cars look fast and clean https://t.co/jlcoY2EjZf
Apr 25
RT @chr1sa: Yesterday we had a record number of competitors (36) in our monthly @DIYRobocars virtual autonomous car race. We kept it going…
Apr 25
Apr 16
DIY Drones via Twitter
RT @chr1sa: After more than a year of only virtual races, @DIYRobocars returns to the newly renovated @circuitlaunch on May 22 for the resu…
Apr 11
RT @DAVGtech: And now available with LiDAR 🔥 https://twitter.com/Heavy02011/status/1381137016381964293
Apr 11
RT @Heavy02011: #VirtualRaceLeague: @DIYRobocars Race #9 - #ParkingLotNerds #thunderhillracetrack, CA Join us for the next race April 24th,…
Apr 11
RT @DWalmroth: Weather's finally cooperating, looking forward to racing 1:10 scale autonomous cars outdoors again! @diyrobocars, @NVIDIAEm…
Apr 7
RT @AIDRI_: I finally succeeded in optimizing the trajectory and speed of a car on a #racetrack. Next step: implement a 2d controller and…
Apr 7
@jetdillo @circuitlaunch Actually the second *in person* event in a year. We do virtual races every month
Apr 2
Update: we're moving it back one day to Sunday (the 4th) at 11:00am instead
Apr 2
