Flight modes
The Ardupilot allows you to have multiple flight modes of which I would actually only need 2 and downsizing has already been discussed but downsizing irrelevant code is not what I want/need.
Could I have two sets of autopilot code one setup for fast servo control, the other setup for slow servo control? (Space permitting or if not remove another mode for space)
Could I add altitude based servo variables? the higher she goes the slower the servos react
I will be using a glider first off (because I dont care if it breaks) so motor control is not needed. Is there a variable for this or do I delete/adjust a section of code
  • I would also like to increase my mode options. to use the mixing option to get 6 modes, will this require reprogramming of the Atiny?
    Thanks for all your help
  • Does anyone know if it is possible to add more than three modes to the control modes? I have a proportional dial on channel 7 on my hitec eclipse 7 and I would love to be able to do manual, stabilize, waypoints and RTL on the same flight.
    I do this when testing....
    void read_control_switch(){
    byte switchPosition = readSwitch();
    if (oldSwitchPosition != switchPosition){
    switch(switchPosition)
    case 1: //
    set_mode(POSITION_1);
    break;
    case 2: //
    set_mode(POSITION_2);
    // set a variable here such as a PID value
    break;
    case 3: //
    set_mode(POSITION_3);
    break;
    oldSwitchPosition = switchPosition;
    // reset navigation integrators
    reset_I();
    You can certainly implement this in your code. Look at the roll slew rate limiter. If you set up a similar pitch slew rate limiter and then set up modes which change the limiter parameters that would do what you want.
    If you are not using a motor then use the airspeed sensor. Elevator will be based on airspeed hold. You can just ignore the throttle parameters.
DIY Robocars via Twitter
Sunday
May 14
May 13
May 13
May 11
May 8
May 8
RT @SmallpixelCar: Test my car. RTK GPS worked great. Thanks @emlid for their support. https://t.co/EkQ6qmjmWR
May 8
DIY Drones via Twitter
RT @chr1sa: @kane That's @diydrones circa 2009. Still have a box of those Canon cameras that we used to strap into planes, just like this.…
May 3
RT @chr1sa: Our next @diyrobocars race is going to be outside at a real RC racetrack in Fremont on May 28. Fully autonomous racing, head-to…
Apr 30
RT @f1tenth: Our Spring 2022 F1TENTH course @PennEngineers is coming to an end with a head-to-head race as a big finale. So proud of our st…
Apr 26
RT @DanielChiaJH: I wrote a thing! Throughout the development of my @diyrobocars car I've been using @foxglovedev Studio to visualize and d…
Apr 23
RT @SmallpixelCar: My new car for high speed. Low body, everything ( @NVIDIAEmbedded Jetson Xavier NX, @emlid RTK GPS, IMC) under the deck…
Apr 23
Apr 21
RT @f1tenth: F1TENTH Race training setup @PennEngineers for our upcoming ICRA2022 @ieee_ras_icra competition. @OpenRoboticsOrg @IndyAChalle…
Apr 21
RT @fatcatFABLAB: Proud to be hosting a restarted DIY Robocars NYC Meetup April 26. Come by if you want to talk about and race self-driving…
Apr 17
