Whats up yall. So there will be profanity in this post. If you have small children have them look away now.
I am on my last wit here. If this cannot get fixed, I will post a video of me blowing up this f*****g quad in some shape or form. All work Flawlessly and the issue came out of absolute nowhere.
So............. New Motors, New ESC's, ALL new wiring. Only the bare essentials connected. Reinstalled Pixhawk firmware. Re-Flashed pixhawk. Re-Flashed Devo Transmitter. Tested quad with pre-arm off. Re calibration of pixhawk. Tried again. Removed power module. Powering pixhawk with 5v leads from ESC's.
The quad cannot leave the ground......It seems as if the quad is EXTREMELY under powered. When at full throttle, the thing runs for a few more seconds, then a full blackout. I mean FULL blackout. ESC's, Flight Controller. even with the battery connected. To power back on, The battery needs to be unplugged and plugged back in again.
PLEASE PLEASE PLEASE PLEASE PLEASE help.....................................for god's f*****g sake.
P.S. I intended on using more profanity.....
  • Can we get ANY data of your quad??picture?video?Anythng...
    • OK, try other tests. You've got a dodgy connection somewhere. Or at least rule it out
      • I'll post the results in a few hours
        • So just doing some continuity tests, if i touch the ground terminal to the signal wire on the ESC, there is a small bit of continuity. Is this normal?
          • It's not strange.  You're reading  through the circuit now.
            Just check grounds to grounds.  Should be far less than one ohm or so.
            Wiggle the wires
            • all grounds make good contact
              Tested the ground rails on pixhawk and receiver as well
              • If i touch the hot wire from battery terminal to the ground, there is a bit of continuity too....does that say anything?
                • The ohm rating increases steadily, could it be the capacitor in the ESC?
                  • Ok, so you left the one test lead on the negative plug at the battery end and tested each of the negatives at the ESCs. They all checked out. Did you rattle and fiddle with the wires as part of the test?
                    Yes, the steadily increasing resistance would be a cap charging up somewhere in the circuit.
                    Right, let's try look at the next thing. Power.
                    Did you measure across the power module?
                    Connect your tester to the Pixhawk RC out +/- The easiest and safest way is to sacrifice a servo extension lead.You should see roughly 5.3V. When you put full throttle does it remain at 5.3 or does it die?
    • OK, suggests it us load related. Try all props off then add one at a time until it trips. Check that esc first.
      Put props on upside down
DIY Robocars via Twitter
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
Monday
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Nov 26
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Nov 25
@gclue_akira CC @NVIDIAEmbedded
Nov 23
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9
RT @JoeSpeeds: Sat Nov 6 Virtual DonkeyCar (and other cars, too) Race. So bring any car? @diyrobocars @IndyAChallenge https://t.co/nZQTff5…
Oct 31
RT @JoeSpeeds: @chr1sa awesomely scary to see in person as our $1M robot almost clipped the walls as it spun at 140mph. But it was also awe…
Oct 29
RT @chr1sa: Hey, @a1k0n's amazing "localize by the ceiling lights" @diyrobocars made @hackaday! It's consistently been the fastest in our…
Oct 25
RT @IMS: It’s only fitting that @BostonDynamics Spot is waving the green flag for today’s @IndyAChallenge! Watch LIVE 👉 https://t.co/NtKnO…
Oct 23
RT @IndyAChallenge: Congratulations to @TU_Muenchen the winners of the historic @IndyAChallenge and $1M. The first autonomous racecar comp…
Oct 23
RT @JoeSpeeds: 🏎@TU_Muenchen #ROS 2 @EclipseCyclone #DDS #Zenoh 137mph. Saturday 10am EDT @IndyAChallenge @Twitch http://indyautonomouschallenge.com/stream
Oct 23
RT @DAVGtech: Another incident: https://t.co/G1pTxQug6B
Oct 23
