Forever yawing
Had a crash and now when connected to mission planner yaw is continuously changing.  It starts at 360 and counts down.  I created a short video showing this in mission planner.  Flying is of course impossible, the copter just starts to yaw out of control.
Any suggestions to fully diagnose this or correct it?   I suspect the gyro is messed up.  I read about reflowing but would appreciate more details on how to do this.  I do have a heat gun.
Thanks!
  • My quad is doing the same thing as well...
  • My problem is more than just what is shown in Mission Planner.  When I attempt to fly, the copter yaws immediately in a fast spin.  I had been flying for a few months without a GPS and without a mag with no issues and I never noticed the forever yawing in MP.  So I assumed what I saw in MP and the spinning during flight was related.
    I tried with 2.0.48 and saw the same yaw in MP.  Though I haven't tried to fly with this build.
    The drift is about 1 degree a second but always in the same direction.  I guess if left long enough it would go all the way from 360 to 0.  Not really a drift... just a countdown.
    I will add a magnetometer this weekend... but I doubt that will change anything.  I really think something is busted from the crash.  I actually have tried a second oilpan yet still have the same results.
    As Todd mentioned... how do I do this: "erasing the offsets and starting over".
    Thanks.
  • I have met the similar problem, I think if it oscillates with in 1 deg should be OK to fly, but the performance is not quite well.
    By the way, my board was purchased quite long time ago, I don't know whether the latest code can work well on it....
    I suggest u to go CLI test to test the compass and imu, if that is OK, then try to use some old version code...
    I am not quite sure whether PID settings will help..
  • I've had similar problems ever since we updated to 2.055, with the problems persisting in 2.1, and seen other users with similar yaw problems (an maybe related roll or pitch problems).
    I was able to get the problem to go away in 2.055 by resetting and erasing eeprom, reinstalling firmware, and re-doing setup. However, I'm having problems getting the same to work in 2.1. Based on my observations, it seems to me that the problem has to do with the compass offsets. It seems that bogus numbers occasionally get created and then a permanent yaw develops, which can only be solved by erasing the offsets and starting over. I don't know if Jason changed the code related to how the offsets are created in these newer firmware versions, but that might be a place to check.
    I could be way off base, but I've seen enough similar problems from others to think that it might be a bug in the code.
    Sounds like you don't have a magnetometer, it's not enabled or perhaps it's broken.  Gyros drift so you normally need the magnetometer to counteract that.
    I couldn't actually see the heading in the video :-(.  Isn't it right at the top but just out of view?
  • I am having a similar issue, I noticed that if I reload the code, setup the radio and everything without turning the APM off, it works fine, i can even fly. But as soon as I restart the APM the yaw gyro isnt taken into account it seems. The IMU test works great, but the APM doesent incorporate the gyro data into flight.
    I am working on it now, I'll let you know what I find.
DIY Robocars via Twitter
RT @a1k0n: @DanielChiaJH @diyrobocars @circuitlaunch Here's my car's view of that race. About 8.4 second lap times for laps 2 and 3... both…
2 hours ago
RT @DanielChiaJH: Great racing against @a1k0n today at @diyrobocars! Pretty cool to both break sun-9s at the track today I think I got very…
yesterday
Broadcasting the @circuitlaunch race live now at https://m.twitch.tv/diyrobocars Races begin around 2:00pm PT
yesterday
RT @a1k0n: ran a huge number of hyperparameter tuning experiments yesterday; now I can train a new policy, far with better quality, in 15 m…
yesterday
RT @a1k0n: Did I get rid of hand-tuned parameters? Yes. Am I still hand-tuning more parameters? Also yes. I have a few knobs to address the…
Sep 26
RT @a1k0n: I'm not going to spoil it, but (after charging the battery) this works way better than it has any right to. The car is now faste…
Sep 26
Sep 26
Sep 24
Sep 24
Sep 24
Sep 23
Sep 22
Sep 11
Sep 10
Sep 10
Sep 10
