Drone racing 4 cell versus 6 cell lipos, what's the big deal what's the difference?
Let's find out.
First of all what is drone racing. Drone racing involves flying aircraft like this one, it speeds an excess of 8200 miles per hour, pilots wear goggles to see a first person point of view from the aircraft, and use radios like this one to control them.
A typical race format involves flying a course of gates and flags for two minutes. At the end of those two minutes, pilots are allowed to finish their final lap, the biggest issue however is finishing that 2 to 2 and a half minute race. Battery technology is currently the most limiting factor in drone racing, it means that lithium polymer batteries like this one are about the only option we have, it also means that energy density must be kept relatively constant across all setups. It's forced many pilots to look for more efficient setups often using higher voltage and lower KV motors. Sam from a future here to explain KV, it's simply the theoretical RPM of an unloaded motor per volt. This makes sense using the equation p equal IV, we can keep power relatively constant by increasing voltage and lowering amp draw. We can also see that 4 cell setups of 16.8 volts paired with 2600 KV motors, relatively similar theoretical RPM outputs as that of a 25.2 volt 6 cell setup with 1750 KV motors.
Other advantages of 6 cell include more consistency throughout the entire flight, more torque at the motors making it fly better and also less stressing electronics, which means less energy is lost as heat. We can compare the 1.05 amp hour 6 cell battery, and the 1.55 amp power 4 cell battery and see that they have very similar watt hour ratings. This means they also have very similar weights, making both aircraft fly very similar for testing purposes. Before doing a more direct comparison of 4 cell VS 6 cell, I think it's important to discuss that recent Open Grove race held in California, pay special attention to the two pilots on the right, these pilots are flying 4 cell setups, the four on the left however are flying 6 cell setups. Before going into a more direct comparison of 4 cell versus 6 cell we must first discuss the recent Open Grove race held in California. This is significant because it was the first race to be held since the rule change allowing for high voltage setups. It also featured many top pilots from around the US, and had a throttle intensive course, showing some of the differences between 4 cell and 6 cell setups. This course also forced many pilots flying both 4 cell and 6 cell to overcharge their batteries. Overcharging is the unsafe practice of charging batteries past their manufacturer recommended limits. Lithium polymer batteries should only be charged to 4.2 volts per cell. Standard overcharging charges to maybe 4.35 volts per cell or even 4.4 volts per cell. Most pilots at this race flying six cell charge to those limits. Though some pilots like Vanover the pilot in the top right were even charging their 4 cell batteries up to 4.75 volts per cell. This LED to one battery fire at the race, and shows the advantage of the more efficient 6 cell setups. Pilots flying 4 cell had to do things like limit their power and take tighter lines, pilots flying higher voltage 6 cell setups had a larger margin of error and could push their setups just a little bit more than those flying 4s. By the end of the race a few things became apparent, most notably of which is the competitive edge that 6 cell provides. Pilots flying 6 cell were able to finish most of their races, while pilots flying 4 cell had to make sacrifices. Free fall on the bottom right was flying some of the most efficient 4 cell motors available, these motors are also less powerful than traditional setups, meaning that taking tighter lines is crucial. Vanover the top right has since become more open to 6 cell setup, given his issues charging 4 cell batteries to 6s voltage.
Next let's look at a side by side comparison of a 4 cell and 6 cell setup. Both quads being flown here are built for a nearly ideal comparison, they both use the same exact components except for motors and batteries and weigh about the same, behind the sticks we have professional pilot Zachary Thayer, fly consistent 19 to 22nd lap times. By the end of the flight, we can use his experience and the on screen data to get an accurate idea of the real world differences between 4 cell and 6 cell.
Let's go ahead and skip to the end of the video to hear his thoughts on the flights and look at the data recorded
Here we are at the end of both flights. First on the main screen we'll see the four cell quad land while the six cell quad on the upper left is able to fly longer and complete another lap. The end of flight data shows us that the aircraft was armed for a total of 2 minutes and 39 seconds pulled a maximum of 114 amps, and driver 16 milli amp hours from the battery. This compared to the six silkwad which flew longer pulled a maximum of 64 amps and drew only 170 milliamp hours from the battery shows the increased efficiency of the six cell setup, given that it was able to fly longer and use a smaller percentage of its battery's capacity.
Now let's hear what the pilot had to say about the flight and his thoughts on 6scel: To me it was the two most apparent parts was the full throttle punch out to the split as it was harder to recover and hit that real flat angle you talked about, where I come down and just hit straight that was harder. I think if you watch it you'll see it bobbles a little more, and then the hairpin right after that through the gate, it was getting harder and harder to get up out of that corner. This longer lasting power at the end of the battery is one of the most notable features of 6 cell quads. It's also consistent with the lower amtral on batteries and leads to greater consistency as a nube will discuss next.
The biggest difference I would say 6s was much easier to pilot due to its consistency, that's something that's going to be hard to bring out as we try to make scientific testing, because you feeling more confident. People will say well that's subjective. So racing there is subject it's a mental game on top of an equipment game, so what I would say my biggest difference is when we did the full send with the 6s, I still felt I could go fast , where as here on the consistency with the 4s which is not a full send towards the end of it I was struggling to stay.
Consistency throughout the entire flight is one of the most important things to pilots, because small changes in handling near the end of the flight can lead to crashes.
When the battery sags on 4s, the biggest thing I started noticing is your tune actually gets looser, it's like you're flying at 3s now with the 6s 1300mah lipo for example, I was able to actually still hit my lines easily due to that that was something that just sort of popped into my head, right now is with the 6s as your lowest voltage actually being higher relative to the lowest voltage on 4s, it feels so much more consistent your quad actually does I think fly more consistent.
Just summarize I think that 6cm really is the future of racing as pilot skills continue to increase
and as races become more and more competitive, we must push the limits of technology further
to achieve longer flight times and more consistent flights. But how does all this relate to physics
well it's an exciting new application of a theory that aims to maintain power while also decreasing amp draw for the benefit of our batteries. FPV racing really is a poor man's F1, where consumers must continue to push available technology to maximize performance. I have no doubt the future of drone racing involves high voltage, it's exciting to see theories like this one paired with real world testing that truly change the sport as we know it.
Develop a secure shopping cart system that allows users to add and manage items easily.
Ensure a smooth and secure checkout process with multiple payment options and address verification.
Payment Gateway Integration:
Integrate popular payment gateways like PayPal, Stripe, or Square to handle transactions securely.
Implement SSL encryption to protect user data during transactions. https://mlsdev.com/blog/how-much-does-an-e-commerce-website-cost
