FrSky DJT-JR 2.4GHz Transmitter Telemetry Module
The DJT telemetry transmitter module is a great choice if your transmiter is compatable with the JR modules. (as well as Turnigy 9x/FlySky 9x/EMAX 9x)
The Telemetry Radio System developed by FrSky provides an additional return link that is used for monitoring the Rx’s voltage, poor receiver reception, temperature, location, speed and so on.
The module is compatible with both the V8-series (non-telemetry) and the D-Series (telemetry) receivers.
Features:
Advanced Continuous Channel Shifting Technology (ACCST is our advanced tecnology it shifts channel hundred times per second and there is no signal conflicts and interruptions) robust frequency agility.
Easy to bind and very fast link-up.
Excellent reboot time.
True Diversity with two antennas.
All channels can be programmed with Failsafe, quickly and easily.
Quick and extremely stable in performance.
Precise and smooth servo response.
Extended range (1.5km-2.5km).
Specifications:
Operating voltage: 6.0V-13.0V (can handle 3S!)
Power consumption: 50mA
Output Power:: 60mW
Resolution: 3072 (11bit)
Dimensions: 63.9x48.5x36.5mm
Version: 2.0
compatiblity:
JR: 347, 388, 783, U8, PCM10, PCM10S, PCM10SX, PCM10IIS, 8103, J9303, PX, 9XII, 11XZERO, Turnigy 9x.
What's in the Box:
1 x 8-channel transmitter module DJT-II (V2)
1 x Transmitter Antenna
