FrSky Receiver TFR4SB is Compatible with FASST 2.4G: Air Systems (7CH Mode/Multi Mode) & Surface Systems (C1 Mode) Finally an affordable S.Bus reciever. Not only is it affordable, but we offer improved sensitivity and stbility for better comunications with your transmitter. Don't let the lower prices fool you, we are puting out some of the world's best R/C radio today.
Features:
SB port is compatible with Futaba S.BUS servos and FrSky servo D12MB. No receiver channel limits (except by those on your transmitter) and prevent mismatched servo-channel connections.
Two selectable failsafe setting options (use native failsafe on radio side or set failsafe on TFR4SB side)
Improved sensitivity and stability
Wider and higher operating temperature range, suitable for all kinds of models
Specifications:
Number of Channels: 16
Dimension: 41x 24x 6mm
Weight: 6.0g
Operating VoltageRange: 3.5V~10V
Operating TemperatureRange: -10°C~60°C
Compatibility:
FASST 2.4G Air Systems (7CH Mode/Multi Mode): 6EX, 7C, TM-7, TM-8, T8FG, T10C, TM-10, T10CG, T12Z, T12FG, TM-14, T14MZ, etc.
FASST 2.4G Surface Systems (C1 Mode): 3PK, 4PK, etc.
Compatible with Futaba and FrSky S.Bus servos.
What's in the Box:
1 x TFR4SB
2x Short tool
1 x Manual
7371997689?profile=RESIZE_180x180
