FTDI cable: 3.3v or 5v
I can see that 3DR sells 3.3v FTDI cables. But I was not able to confirm by searching this forum if 3.3v is the only option or if a  cable with TTL level of 5v will also work ?
I already have a 5V cable and I just don't want to try it and fry my module.
Regis
  • Note that VCC is 5V, only the signal wires are 3.3V according to 3DR and the cable manufacturer's spec sheet.
    3DR's page states: "Note: The TX/RX signals are 3.3volts, making it even more flexible, the power supply is 5volts (red wire)."
    Why do they state it is more flexible?  Will a 3.3V signal work with a 5V system?
    Also, if your board is using 5v signaling, I hope that won't harm the RS232/USB convertor chip inside the cable (which expects 3.3V).  took me awhile to realize FTDI is simply a company which makes the RS232/USB convertor chip...dumb idea whoever decided to refer to them as FTDI instead of RS232.
    • Hi Eric
      Just a quick question did the 5v signal cause any harm to the OSD ? I've just bought a FTDI breakout but see now that it's 5v logic .
    Either cable will work. The 3DR radio actually works for input power down to about 3v, and the serial interface is 5V tolerant.
  • Ok. I spent some time searching this forum but I did not really read the product page on the 3DR store. And it says:
    "Interface to the module is via standard 5V-tolerant TTL serial / FTDI USB serial."
    So why is a 3.3v cable sold with the module.
    Regis
