Gimbal Control in 2.5.x
My APM2 quad flies very well.  My gimbal control works well also, and with the advanced settings have calibrated it to stabilize my gopro OK.  But the movement is slower than other FC's I've used, more noticeably around the center position.  It acts as if there is a "D" value slowing it down in the center.
Is anyone else using a gimbal and doing well?  Maybe it is my setup.  I have abandoned my NAZA in favor of the APM2, but the NAZA was very quick in gimbal control.
  • What is needed is simply a linear system.  Right now the gimbal control is too slow to keep up with the movement.  If I roll the quad and then return, the gimbal slowly returns to center, it creeps the last little bit.  No dampening is needed here.  Much of the strength and speed of the gimbal is dependent on the servos, mine are designed for gimbals and are fast.  But the APM2 is slowing the response given to the servos compared to quad movement.
    I was hoping someone else was using the gimbal control and will let me know if they had the same response.
