Hi People,
This is a simple question I am having for some experts out there. I am getting a GIMBAL LOCK problem when I pitch my APM-1 board 90 degrees (downwards), the roll and yaw values becomes crazy.
My current implementation uses ahrs.pitch_sensor (euler angle) values.
Can anyone tell me how to prevent this problem using  ahrs.get_dcm_matrix() or using the Quaternions (in this case I am not sure how to call update, as this class does not have one).
I am looking for a solution to this problem with logic and\or code. HELP is really appreciated!
Thanks in advance.
  • T3
    Hi Shyam,
    In case anyone who read this thread is still interested, you and I figured out that you were running into a gimbal lock problem with Euler angles. There were a couple of possible solutions, including using direction cosines instead of Euler angles. However, you and I came up with a simple solution that allowed you to use Euler angles, which you posted here.
    Best regards,
    Bill Premerlani
  • As I understand it, there is a fundamental problem with converting the dcm rotation matrix to roll, pitch, yaw.  If you stay with with the DCM rotation matrix then you don't have this problem.
