0 Gimbals for Xiaomi Yi action cam (Chinese Gopro) Posted by Alpha on June 4, 2015 at 7:37am Hi guys, Pls suggest some best and budget 3 axis and 2 axis Gimbals for Xiaomi Yi action cam (Chinese Gopro) for my APM 2.6, F450 clone Quadrocopter. You need to be a member of diydrones to add comments! Join diydrones Tags: 2, 26, 3, 5000mah, apm, action, aerial, axis, cam, camera Email me when people reply – Follow
I have a walkers g2d and g3d, I just filed down the gimbal to accommodate the slightly larger xiaomi yi.
Xiaomi yi in 3 axis g2d and 1 axis gimbal
This one is xiaomi yi on g2d
Thanks !! Jun Yamog the Video was spectacular, but there is a little wobble, is that due to the gimbal ? and can you post the pics of your Setup.
The V550 flights (1 axis gimbal) where you can see the rolls as only pitch is compensated has a post production stabilisation applied. This causes the wobble.
I don't have the photos of the gimbal, but here is some build notes
http://jkyamog.blogspot.co.nz/2015/06/h600-quadcopter-alternative-b...
http://jkyamog.blogspot.co.nz/2015/04/built-cheap-quadcopter-then-u...
I don't have a good writeup of my f450.
