GPS + xbee project
I'm working on a simple GPS Xbee tracking project.
It seems that you can directly connect a gps with NMEA output to a XBEE and send the data over to a xbee connected pc.
I've tried this but it doesn't really work. I get data but its unreadable.
My setup is the following
GPS                XBEE                               ~~~~~~~~~~~~~        XBEE       Expl board     USB PC
TX ---------------DIN
5V ---------------5V-----------------5V Batt
GND ------------GND--------------GND Batt
I'm using a mediatek GPS set at 4800bps and two XBEE 2,4Ghz also set at 4800 bps.
On the pc side the xbee is connected with an usb explorere board and I'm using hyperterminal to read the incoming data on Com10.
Does someone have a solution to this?
Thx
  • some evolution?? the same thing happened to me ... the 3DR receives  the information, but are not recognized. if I connect my GPS with the FTDI works perfectly.
  • hi, have you manage to make this working? connecting a gps dirrectly to an XBEE module? thanks
  • Any more suggestions??
  • If it's the MediaTek from DIYd, how did you change it to NMEA from the custom binary protocol it ships with?
