Grouse House Technologies EZ-Gimbal With A Twist
img_3946.jpg?width=700
Presenting the EZ-Gimbal With A Twist. You can now rotate your camera into a portrait orientation to enable portrait photography and panoramas.  Due to the unique three axis balance adjustment system of the EZ-Gimbal, the rotation by 90 degrees requires NO rebalancing.  You can alternate between landscape and portrait orientations without touching the cameras balance position.
The pitch assembly has two plates which the long narrow camera base plate attaches to (with long straight slots).  With the camera in the landscape orientation you can adjust the camera fore/aft and up/down positions to set the balance.  You can then rotate the camera 90 degrees to the portrait orientation and slide the camera up/down (left/right slider when in landscape orientation) to set the balance in that orientation.  With all three axis set to the cameras COG you can then alternate between the two orientations without touching any settings.  The camera rotates on its own COG.
img_3949.jpg?width=700Total width for your camera is 15cm so plenty of room for up to an NEX-7 sized camera (NEX-6 pictured).
img_3947.jpg?width=700​Two strong and lightweight aluminium supports attach the camera tray to the up/down slider plate. Also, the side arms are reinforced to minimise any sideways flex.  2 and 2.5mm high quality carbon fiber components make up the main frame and 3mm carbon fiber is used on the two positional adjustment plates.  This is a very strong, rigid and lightweight gimbal.  At approximately 400g with all the electronics you can't go wrong. Other gimbals on the market of this size with less ease of use and functionality start at 500g+.
What really stands out with this design is the ease and speed at which it takes to find the correct balance.  If you have a range of camera's that you plan on putting up in the air it won't take you long to balance each time you swap the camera over.  Also, the weight of the pitch back plate assembly counter-balances the camera, allowing you to place the camera one or two cm further forward on the tray.  This effectively places the camera's sensor much closer to the pitch line of rotation.
Another large benefit of this design is the ease of access to the battery/SD card hatch of your camera. You no longer need to unscrew the camera from the mount to replace the battery or access the SD card, saving you rebalancing time.
Each EZ-Gimbal comes with two LD-Power 4008-57 brushless gimbal motors and a V3 Martinez Open Source Gimbal Control board/IMU.  On top of that it comes with one regular length camera support tray and one extended for camcorders (up to Sony PJ790 size).
You also have the choice of supplying your own connection between the roll motor and your multicopter by just selecting NONE for the connection option.  This is a good option for those wishing to upgrade from the NEXt-Gimbal to the EZ-Gimbal With a Twist.  In this case the two vertical rods are also omitted from the gimbal purchase.  You just unscrew the four screws on the roll motor of the NEXt-Gimbal and attach the roll motor of the EZ-Gimbal With a Twist.
There is also a third axis mount option with ball damper available which fits this and all my designs available on my store.
Please visit www.grousehousetechnologies.com.  If you have already visited over the last couple of months you will be pleasantly surprised by the new prices on not only the products but also the postage.
DIY Robocars via Twitter
Videos from the ICRA autonomous racing workshop are now available: https://linklab-uva.github.io/icra-autonomous-racing/
Thursday
RT @SmallpixelCar: Prepared race track for Warm Spring Raceways @wsraceways and looking forward to test my new car at RAMS RC @ramsaicar fa…
Jun 6
RT @f1tenth: Trying out some nasty blocking maneuvers 🏎️🤖 #f1tenth #autonomousracing https://t.co/nMTstsaogM
Jun 5
May 27
RT @araffin2: I will talk this Saturday from 18:00 to 19:00 Paris time for the @diyrobocars community about learning to race in hours using…
May 27
RT @a1k0n: Luckily the infeasible hairpin problem was easily reproducible in simulation and I could test the fix before bringing the car ba…
May 26
RT @a1k0n: Another problem was that I was over-constraining the car's allowed accelerations, so it didn't think it could turn as tight as i…
May 26
RT @a1k0n: Breaking the map up into two halves worked, but I had to be more careful about separating the inner track from outer. There's se…
May 26
RT @a1k0n: Here's a datalog for my fastest lap of the day. Lap timer is tiny window lower-left. https://t.co/myrlWWrKUY
May 26
May 26
RT @a1k0n: Here was my car's POV. Man this track is confusing in first-person! After the incident my camera was all scuffed up and I was af…
May 23
RT @circuitlaunch: Loved seeing so many familiar (masked) faces at Circuit Launch today for our first in person @diyrobocars in over a year…
May 22
RT @circuitlaunch: Last but not least, mystery guest @BostonDynamics Spot took to the track @diyrobocars He enjoyed the #brazilianbbq too 😂…
May 22
RT @SmallpixelCar: Today’s race @circuitlaunch for @diyrobocars with @a1k0n Was busy in the morning and did not get a chance to tune camera…
May 22
RT @a1k0n: This was epic. My car was barely working this morning, had to make a lot of changes and extremely dirty hacks. Post-race analysi…
May 22
DIY Robocars @ Circuit Launch, 3/7/2020 https://twitch.tv/diyrobocars
May 22
