GY-63 MS5611 interface with Arduino (Due)
I am desperately in need of guidance for the interfacing of GY-63 MS5611 barometer with Arduino Due. I cannot even start the communication with Arduino.
Any help or guidance would be appreciated.
I will be extremely grateful for an urgent response!
  • Hi Omair,
    "I cannot even start the communication with Arduino."
    Can you successfully compile and upload a sketch? How have connected the gy-63? What code do you have so far?
    • Thank you for your response.
      I have downloaded the "i2c scanner for arduino" which allows you to detect an i2c comm link. I am able to compile it but it says No Devices Found.
      I have setup the GY-63 MS5611 exactly as said by the datasheet here:
      http://www.meas-spec.com/downloads/MS5611-01BA03.pdf   (Page 17)
      I have tried this much so far.
      • Can you please be specific as to how you are powering your gy-63 and exactly what pins on your due you are using
        • I am powering GY-63 by the 5V output pin on Arduino Due.
          i am using the SCL (Pin 21), SDA (Pin 20) on the Arduino Due to connect to SCL, SDA pins on GY-63. I am also using 10K pull up resistors for the SCL, SDA pins of GY-63.
          • Have you connected PS high?
            Page 14:
            PS high (VDD) => I2C
            PS low (GND) => SPI
            • Yes, I have done so.
              I have also tried connecting the CSB pin to high as well as low. No benefit.
              • Hmmm... that seems to cover the basics.... I have a Due + GY-63 at the office - I will check for you tomorrow (approx 12 hrs)
                • Thank you very much. I will be eagerly waiting for your response.
                  • Omair,
                    I am glad you got it to work. Unfortunately I have not ever had to interface this sensor to the Due previously so I have no code on hand to share. I see there are a few Arduino libraries around for this sensor but I suspect none of them will compile directly for the Due. I just downloaded the FreeIMU library from:
                    http://www.varesano.net/projects/hardware/FreeIMU#library
                    and with a bit of tweaking, managed to compile both:
                    libraries\MS561101BA\examples\MS561101BA_simple.pde
                    libraries\MS561101BA\examples\MS561101BA_altitude.pde
                    I am based at our head office today and do not have access to the Due or sensor to check if this was successful. As it is Friday today, I will not be back at the office until Monday but can check the code then.
                    I have attached the altered FreeIMU files so you can have a go yourself
                    MS561101BA.cpp
                    MS561101BA.h
                    FreeIMU: an Open Hardware Framework for Orientation and Motion Sensing | Varesano.net
                  • Omair,
                    I encountered the same issue you describe using a similar setup. It looks like there is a bug in the Wire library that is causing a problem with the Due. You can download the very latest master version of Arduino from:
                     https://github.com/arduino/Arduino
                    or just update Wire.cpp from here:
                    https://github.com/bluesign2k/Arduino/blob/63f0ca06a8af7a223aacca8b...
                    This fixes the problem for me.
                    arduino/Arduino
                    open-source electronics prototyping platform. Contribute to arduino/Arduino development by creating an account on GitHub.
