GY-63 MS5611 interface with Arduino (Due)
I am desperately in need of guidance for the interfacing of GY-63 MS5611 barometer with Arduino Due. I cannot even start the communication with Arduino.
Any help or guidance would be appreciated.
I will be extremely grateful for an urgent response!
  • Hi Omair,
    "I cannot even start the communication with Arduino."
    Can you successfully compile and upload a sketch? How have connected the gy-63? What code do you have so far?
    • Thank you for your response.
      I have downloaded the "i2c scanner for arduino" which allows you to detect an i2c comm link. I am able to compile it but it says No Devices Found.
      I have setup the GY-63 MS5611 exactly as said by the datasheet here:
      http://www.meas-spec.com/downloads/MS5611-01BA03.pdf   (Page 17)
      I have tried this much so far.
      • Can you please be specific as to how you are powering your gy-63 and exactly what pins on your due you are using
        • I am powering GY-63 by the 5V output pin on Arduino Due.
          i am using the SCL (Pin 21), SDA (Pin 20) on the Arduino Due to connect to SCL, SDA pins on GY-63. I am also using 10K pull up resistors for the SCL, SDA pins of GY-63.
          • Have you connected PS high?
            Page 14:
            PS high (VDD) => I2C
            PS low (GND) => SPI
            • Yes, I have done so.
              I have also tried connecting the CSB pin to high as well as low. No benefit.
              • Hmmm... that seems to cover the basics.... I have a Due + GY-63 at the office - I will check for you tomorrow (approx 12 hrs)
                • Thank you very much. I will be eagerly waiting for your response.
                  • Omair,
                    I am glad you got it to work. Unfortunately I have not ever had to interface this sensor to the Due previously so I have no code on hand to share. I see there are a few Arduino libraries around for this sensor but I suspect none of them will compile directly for the Due. I just downloaded the FreeIMU library from:
                    http://www.varesano.net/projects/hardware/FreeIMU#library
                    and with a bit of tweaking, managed to compile both:
                    libraries\MS561101BA\examples\MS561101BA_simple.pde
                    libraries\MS561101BA\examples\MS561101BA_altitude.pde
                    I am based at our head office today and do not have access to the Due or sensor to check if this was successful. As it is Friday today, I will not be back at the office until Monday but can check the code then.
                    I have attached the altered FreeIMU files so you can have a go yourself
                    MS561101BA.cpp
                    MS561101BA.h
                    FreeIMU: an Open Hardware Framework for Orientation and Motion Sensing | Varesano.net
                  • Omair,
                    I encountered the same issue you describe using a similar setup. It looks like there is a bug in the Wire library that is causing a problem with the Due. You can download the very latest master version of Arduino from:
                     https://github.com/arduino/Arduino
                    or just update Wire.cpp from here:
                    https://github.com/bluesign2k/Arduino/blob/63f0ca06a8af7a223aacca8b...
                    This fixes the problem for me.
                    arduino/Arduino
                    open-source electronics prototyping platform. Contribute to arduino/Arduino development by creating an account on GitHub.
DIY Robocars via Twitter
RT @knightsautoteam: Hi @diyrobocars, we are Orlando's first Autonomous racing club and would love your support. We are hosting our first K…
Jan 20
RT @Heavy02011: #VirtualRaceLeague: @DIYRobocars Race #14 - #ParkingLotNerds join us January 15th for #AutonomousRacing #RoboRace ⁦@DAVGtec…
Jan 16
RT @chr1sa: And after that came our races, 50 in all. This battle between these two Russians was the best we've ever seen -- incredible fig…
Jan 16
RT @chr1sa: Before our @DIYRobocars virtual race this weekend, we had a presentation from the team that won the Indy Autonomous Challenge i…
Jan 16
DIY Drones via Twitter
Dec 12, 2021
Dec 12, 2021
RT @chr1sa: Just a week to go before our next @DIYRobocars race at @circuitlaunch, complete with famous Brazilian BBQ. It's free, fun for k…
Dec 4, 2021
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
Nov 28, 2021
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Nov 26, 2021
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Nov 25, 2021
@gclue_akira CC @NVIDIAEmbedded
Nov 23, 2021
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23, 2021
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23, 2021
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20, 2021
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20, 2021
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9, 2021
