Posted by Samuel Shao on February 7, 2015 at 7:58pm
This octocopter is designed and built by myself,for spraying pesticides. wheelbase140CM,Max payload 15kg.made of pure carbon fiber board by CNC,and foldable in order to easy to carry!
The aircraft looks very good. If may I ask, can you share the description of the components you used to assembly the copter? I mean, reference of motors, ESCs, battery and frame. I am building an hexacopter for crop spray purposes, but the motors are not strong enough to carry out the payload needed at 50% of throttle.
Impressive!!!! :O , only a suggestion, Isn't better to put the spraying arms lower? not to have the tank disturb and more damage on motors and electronic with pesticide?, another idea, if the tank is nearer the main plate, perhaps it's better to equilibrate and the pump in one side, waiting for the video, Good luky first fly :)
The CoG could give you trouble, beeing low with the full tank and getting up when the tank depletes. be careful, and test it on both situations with same gains to see what happens, then tune it for the worst case.
Samuel Shao > Ricardo AffonsoFebruary 11, 2015 at 12:50am
Thank you for your good advice,I had thought about this question,at last I use this design is for reducing the affect of concussion of pump to parts on center plate such as imu etc.
Hey Samuel
Many thanks
There will be a clear answer after test!
What a monster! Very cool.
Thank you!
now all works is OK! just waiting for a sunny day to test!
Make sure you take a video. You know the saying - pictures or it didn't happen. :-)
Yeah,thank you forI won't forget it. :-)
Weahther is not good.Maybe it will delay a few days!
