How do I report a bug of Mission Planner?
As the title says, I couldn't find a way to report a bug on the latest Mission Planner to the devs. Does anyone know the proper channel to do that?
After upgrading to the latest MP (1.3.19), the MP doesn't open anymore and it crashes on the splash screen. Even uninstalling and reinstalling a couple of times didn't fix it.
3691178787?profile=original
Cheers,
Hugo.
    please post your config.xml file inside the mp directory.
    and then delete it
    • Not all bugs can be picked up in log files. It's not really critical but the motor test for tricopter is a laugh. Motor C toggles the server. If you have a second it is minor but it has save a few problems for my quadcopters in  the past.
      Cheers.
    • hi i have the same problem. it is not responding on the start screen. and im not finding the config file. what should i do ?
    • Huge thanks, Michael. Crazy you found the time to reply here. That worked great, I should have thought of deleting the whole folder after uninstalling.
      Here's the config file attached.
      config.xml
      • i have the same problem did u fix it and how ?? and im not finding the config.xml file in the directory
  • https://github.com/diydrones/MissionPlanner
    In the mean time, try APM Planner 2
