Hi all,
I have problem with configurations of the switches:
http://pixhawk.org/users/system_modes
In mission Planner:
Now only one switch work, everything is calibrated(all switches).
So with graupner mx-20 and gr-24, how to configure PIxhawk flight modes?
I read something for switch 5, but I don't understand nothing.
Hi again,
now I have problem with the channels:
The RC is in airplane mode, and stick mode 1.
The controls are:
- the left side of the RC are the throttle and yall;
- the right side are the roll and pitch.
The problem are the roll and pitch - THE CHANNELS ARE REVERSED.
- When I put forward i go to right, when i pull back, go to left. :(
What can I do?
RTFM, then reverse the channels. :)
You should try to open the manual, the radio offers many nice features you'll never discover unless you spend some time with it.
I am writing because I couldn't find them.
There is a section in the manual:
-Joystick setting:
Detail program description - Joystick setting.
And I am not sure, after I read the manual can I use it for reverse the channels?
-Another option that i see is the Wing mixers;
I will test today, if any other idea you have, you could write.
Thanks, have a good day.
Under "servo adjustment" - change the arrow direction to invert. :)
This is only if the channel is reverse. :)
Maybe there is some misunderstanding:
- when it has to be pitch it act like roll. This was the problem.
And yesterday I made it, it is easy to change them from "Advance list parameters". You can assign the channels manually(I forgot exactly which parameters I changed), but it's very easy, there is description in the right for this.
To reverse one channel you can set again manually at:
chNUMBER_REV -1
My new settings for PID are:
"P" for roll and pitch are 0,30, it's react very fast.
"D" and "I" are 0.0000
So now it works perfect.
But now I have another problem:
- at my transmitter, I am almost at the middle of the sticks and the copter react like I am at the end.
So from Pixhawk is there a option to make it work with all way of the sticks?
Maybe is normal in stabilize mode to be so aggressive.
sorry : "failsafe"
When the receiver loses connection.
that's easy if you use with PWM , and even easier with PPM connection - easily set up in mission planner or APM planner.
I suggest you check out documentation on ardupilot.com
Thank you,
All is good now, but I have problems with config of PID..maybe.
new discussion
My way, is to mix CTRL9 + SW8 directly in MX-20 , then send output in one channel.
If you understand my notes /(I expect you to do) :) - and do it right, there's no adjusting or tuning - all 6 modes will be hit perfectly within PWM limits.
Input5 Ctrl9 (Ct9)
Input10 Sw8 (8)
Servo adjustment
S5 travel 65% 59%
S10 travel 70% 85%
Free Mixers
fr10->to5
symmetric +20% +20%
ch5= main mixed output
Enjoy :)
