Hey guys,
After many difficulties, I've been able to connect my Transmitter to my APM.
I would like to setup my flight modes, but the mission planner indicates that my APM is listening on Channel 8 (Current PWM).
For the flight modes my receiver is linked to my apm using the channel 5 or 6 (Aux 1 white wire or Aux 2 orange wire) (see picture below).
3691085278?profile=original
So is it possible to change the current pwm parameter to channel 5 or 6?
Or do I need to add an extra wire to connect my receiver to the input 8 ?
Thanks for your help
Arnaud
  • Hello, This is my first time responding to anything here so please excuse any obvious
    Mistakes or syntax errors...lol
    I am having a similar problem. I finally got the flight mode to work on Ch5! HOWEVER, now
    my channels are showing (according to the Qground station channel monitors) as follows:
    CH1 SWC
    CH2 ROLL
    CH3 PITCH
    CH4THROTTLE
    CH5 FLIGHT MODE MIX OF SWF AND SWE
    CH6 YAW
    CH7 no response
    CH8 SWB
    THIS IS ALL REGARDLESS TO HOW I HAVE THE TRANSMITTER SETUP. IT's  A radiolink
    Someone help please! Thank you SO MUCH...
    David S.
    https://storage.ning.com/topology/rest/1.0/file/get/3702411735?profile=original
  • I had a problem with changing of PWM value to set different flight modes. As I toggled my three position switch which is already set to channel 5 nothing was happend. The problem was solved by connecting of receiver (I have FS-iA6) output channel 5 to board (I have APM 2,8) input channel 5. That's it! You can set and change your flight modes or everything You want!
  • Hi Amulya! I have the same problem with my APM 2,8 board and Flisky-i6 transmitter. Have you solved the problem?
    Amulya Agarwal said:
    I am using mission planner 1.3.44. There is no MNT: MODE_CH that I can find. Which version are you using @Darren Smith. My current PWM and MODE in the "Flight mode" is always same even if I change the throttle or anything else via the controller.
  • I am using mission planner 1.3.44. There is no MNT: MODE_CH that I can find. Which version are you using @Darren Smith. My current PWM and MODE in the "Flight mode" is always same even if I change the throttle or anything else via the controller.
  • Solved.
    Looking under the config/tuning, I found MNT:MODE_CH and changed it to 5.  Now everyone in my family is happy.
    Darren Smith said:
    I'm using Rover v3.1.0 and want to change the flight mode switch to channel 5 from my transmitter.
    On Mission Planner, I'm looking at; Config/Tuning>Standard Parameters, but there's no FLTMODE_CH parameter.
    How do I change this?  (feel free to be specific).  Thanks in advance
  • Hi,
  • Set FLTMODE_CH to 5 in the full parameter list.
  • Hi,
    You can take any channel on the receiver that you like, and wire that to channel 8 on the APM. It will not control flight mode.
    I would suggest that if possible, you also use channel 8 on the radio. Less confusing that way.
    What do you mean with "current pwm parameter"?
    Regards
    Søren
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
Oct 13, 2022
RT @araffin2: 🏎️ After hours of video editing, I'm happy to share a best of my Twitch videos on learning to race with RL. 🏎️ Each part is…
Oct 13, 2022
