I can not calibrate throttle channel
Hi
my setup:
Mission Planner 1.3.28
ArduPlane v3.3.0
When I try to calibrate transmitter (initial setup-> mandatory HW-> radio calibration-> calibrate radio )
I am not able to calibrate throttle channel. Slider work well but red lines ( corner case value ) does not move.
3691217465?profile=originalWhen I start amp throttle work for a while (5s) then stop reacting
Any idea what can be wrong ?
  •  Arm throttle
    • As usual my fault :). I am building flying wing and I do not use rudder, so when I make a connection between receiver CH4 and AMP input 4 everything works properly. Thank you Watts
    • Thank you for your early reply. In config/tuning is paramater set as  ARMING_REQUIRE=0, but I can not stil control  throttle. So I have no idea what I am doing wrong :(
