For an engineering project for high school, I have chosen to build an automated delivery drone, capable of carrying 1 kg of cargo, in addition to the dropping system we are going to build.
I need help optimizing this build for flight time, flight range, durability, and low cost (under $300 at most).
I think the props need to be large, and motors at low kv, for decreased power draw as a trade off for maneuverability. However, I know little of how to select motors and props and I know there is a lot of complex factors in that choice. This is where I need the most guidance.
I envision a quadcopter being a good choice, but it does not need to be a quadcopter.
As for a transmitter, I will be buying a cheap one, if at all. The drone will be automated, so a controller will only be needed for the initial testing phase and will not be as important once it is up and flying.
Heres my hobby king shopping list:
Quantity     Stock     Product description        Price     Weight
4     OK     171000436-0 - NTM Prop Drive 28-30 800KV / 270W Brushl..                    $60.20     320
3     OK     017000065 - 12x4.5 SF Props 2pc Standard Rotation/2 ..                         $13.08     240
5     OK     HKz30A - HobbyKing 30A BlueSeries Brushless Speed..                             $55.30     235
1     OK     HKz-Prog - HobbyKing Programming card for BlueSerie..                             $3.28     17
1     OK     HK-T6A-M1 - Hobby King 2.4Ghz 6Ch Tx & Rx V2 (Mode 1..                         $25.06     998
1     OK     FS-L001 - Hobby King 2.4Ghz 6Ch Tx USB Cable                                         $2.85     60
1     OK     015000095 - XT60 to 4 X 3.5mm bullet Multistar ESC P..                             $3.36     34
4     OK     SHT007 - NTM Prop Drive 2830 Series Replacement Shaft                           $3.28     52
4     OK     NTM28-ACC - NTM Prop Drive 28 Series Accessory Pack                             $7.40     88
TOTAL: $173.81     2044g
and Amazon:
Sky Tools 127 Piece Heat Shrink Tubing Assortment        $6.99   1
Vktech 40x 3.5mm Gold-plated Bullet Banana Plug Connector RC Battery                                 $3.99 1
SunFouder 2 pcs Ultrasonic Module HC-SR04 Distance Sensor                                                  $8.99 1
NEEWER® Useful HJ MWC X-Mode Alien Multicopter Quadcopter Frame Kit Red/White               $16.99 1
Hobbypower Top Pin APM2.6 External Compass APM Flight Controller w/ UBLOX NEO-6M GPS    $69.89 1
FTDI Cable 5V VCC-3.3V I/O        $17.95 1
Hobbypower Power Module V1.0 for Pixhawk Apm2.5 Apm2.6 Ardupilot Mega Flight Controller    $11.101
Neewer Servo Tester CCPM Consistency Master Checker 3CH 4.8-6V                                         $6.95 1
Subtotal (8 items): $142.85
I am going to use a VEX robotics motor to drive the dropping mechanism, they are
reliable geared motors and it will cost me nothing. I will wire voltage from the battery and
servo signal from the APM, they never draw more that 5A so it shouldn't affect anything.
FTDI cable is to set baud rate and name of bluetooth module (JY-MCU slave)
    -Can the APM 2.6 take serial input coordinates and route to them? (I am willing to code it myself)
I already have a battery and charger, so that saves ~$60
   The Turnigy nano-tech 4500mah 3S 25~50C Lipo Pack is what I already have, and seems like a good choice to maximize flight time to increase delivery range, but is pretty heavy.
I have a mix bag of those little plug wires, and 3 wire ones at the school I can use.
The distance sensors are for collision avoidance, is there any reason not to use those?
    -Can I add code to stop and rotate until it is clear of obstruction? We do that in vex with robots, any reason this would be hard on APM?
The frame is inexpensive, if it does break, then we will build a H frame, but I want something to start with.
        (also it looks cooler than any welded aluminum frame I could make)
Anything I can cut cost on? $316 subtotal + ~$40 for hobbyking shipping (yikes!) is within the budget.
Anything I forgot?
Thank you for reading my post, if you have any knowledge that can help me succeed in this project, I would love to hear from you.
  • Can I connect with you, maybe on Facebook. Delivery Drone is my final year project and I really need help
  • All of the parts showed up, put it all together today and took a test flight. It flies easily and deftly. I'll post a youtube video soon.
  • This is hobbyking's APM board, the reviews are positive and it should be able to do everything we need to too, and has telemetry for far less cost that 3DR's package:
    http://www.hobbyking.com/hobbyking/store/__58283__HKPilot_Mega_2_7_...
  • The diy foam tube frame shown here: https://www.youtube.com/watch?v=5XinbTcQAAc
    looks like a possible frame that would cost practically nothing.
    Its very light, and the lack of hardness means it won't transfer vibrations to the electronics, but that also means it's flimsy.
    What would be the advantages of something like that? If it's practical to use that kind of construction, the budget would relax a bit. Also, mounting the drop mechanism will be much easier with the H-style square frame.
    YouTube
  • I did some more research and came up with this:
    flight computer: apm 2.6 with ublox gps
    http://store.3drobotics.com/products/apm-2-6-kit-1
         $240
    frame: Tarrot fy 650
    http://www.helipal.com/tarot-fy650-quadricopter-frame-set.html
        $130
    motors: Rctimer 5010/14 360KV
    http://www.rctimer.com/product-575.html
       $73 for four
    props: 16x5.5" Carbon Fiber
     http://rctimer.com/product-841.html
        $35 for four
    battery: 4500 mah turnigy nano tech
        $0 I already have this
    esc: 4 in one 20A Qbrain esc
    http://www.hobbyking.com/hobbyking/store/__36674__q_brain_4_x_20a_b...
    optional:
        3DR telemetry kit for data collection
        $100, a bit too expensive to be justified for this project
    apm, frame, motors, props, rxtx
    240 + 130 + 73 + 35 + 25 =
    $503
    The APM is expensive, but for a good autonomous system it seems to be the best value
    The frame is still expensive and heavy- but cheaper frames only seem to get heavier.
    Is there an advantage of the expensive CF props, or are the wide plastic one comparable?
    assuming I can find a cheap frame or make one out of pvc, and get cheaper props, that puts it at
    240 + 40 + 73 + 15 + 25 =
    $393 which is better but I don't know if that's feasible.
    The computer is 60% of that cost, but any cheaper APM's turn out to be Chinese knockoffs.
    Thoughts on where to go from here?
    • Re the frame if you can find someone with a 3d printer locally maybe they can print you a frame. You can get a real nice frame for not much cost in filament. Look on Thingverse for many options.
      Greg
      • We have a makerbot printer at my school, but to fit the large propellors, the frame has to have a 1 foot radius, and at that size I feel like it would get heavy; most 3d print frames are for smaller quads. Is there a particular print on Thingverse you think would work?
        The large prop size is for the sake of efficiency at the cost of maneuverability, which is optimal for carrying a load in a straight line over a few kilometers. Am I correct in thinking that is how prop size affects performance?
    • you'll need a transmitter- I dont think flight without one is available with the firmware. Also be weary about going large- you'll have to fly in biigger places and flying near people/things becomes way more dangerous, and crashes can  be more costly
      • I agree having a smaller size would be better, what size would you recommend for carrying one kilogram one kilometer away, dropping it, then flying back unburdened, and costing ~$300 to $400?
        Do you know if any cheaper flight controllers than the APM 2.6 could support multiple waypoints and low level programmability? We need to fly to GPS coordinate, turn a servo, fly to another, turn a servo, then fly back to home. APM can do that for sure, but at nearly $300, it's way out of budget.
  • you have to redo your whole setup, even if it flies it probably might just fly for a few minutes - it seems like you started with an idea and just went and purchased parts. 1kg payload delivery drone under $300 is not an easy thing to do if you want reasonable range/time.
    Before we start, how about you tell us a few details:
    1. What is the targeted flight time?
    2. What is the targeted range?
    3. How is the drop mechanism mounted? Rails or hard mount?
    Essentially, suggest you work downwards from an objective-oriented approach. Let us know the objectives and we can give some suggestions.
DIY Robocars via Twitter
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
16 hours ago
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Thursday
@gclue_akira CC @NVIDIAEmbedded
Wednesday
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Wednesday
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Wednesday
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9
RT @JoeSpeeds: Sat Nov 6 Virtual DonkeyCar (and other cars, too) Race. So bring any car? @diyrobocars @IndyAChallenge https://t.co/nZQTff5…
Oct 31
RT @JoeSpeeds: @chr1sa awesomely scary to see in person as our $1M robot almost clipped the walls as it spun at 140mph. But it was also awe…
Oct 29
RT @chr1sa: Hey, @a1k0n's amazing "localize by the ceiling lights" @diyrobocars made @hackaday! It's consistently been the fastest in our…
Oct 25
RT @IMS: It’s only fitting that @BostonDynamics Spot is waving the green flag for today’s @IndyAChallenge! Watch LIVE 👉 https://t.co/NtKnO…
Oct 23
RT @IndyAChallenge: Congratulations to @TU_Muenchen the winners of the historic @IndyAChallenge and $1M. The first autonomous racecar comp…
Oct 23
RT @JoeSpeeds: 🏎@TU_Muenchen #ROS 2 @EclipseCyclone #DDS #Zenoh 137mph. Saturday 10am EDT @IndyAChallenge @Twitch http://indyautonomouschallenge.com/stream
Oct 23
RT @DAVGtech: Another incident: https://t.co/G1pTxQug6B
Oct 23
RT @DAVGtech: What a great way to connect why @diyrobocars community is so valuable and important! Have to start somewhere @IndyAChallenge…
Oct 23
