hello everybodies,
like i say , i have a pixhawk system in a xuav talon with vtail mixing, fly nicely in stabilize mode , but impossible to roll or bank in FLBWA modes, so cant fly auto mode for waypoints .......
houston we got a problem !! mayday !
thank
hello,
after few days, i finaly maked a rc calibration , and all work great,
From the Manual http://plane.ardupilot.com/wiki/roll-pitch-controller-tuning/#METHOD_1
I'd recommend reading the wiki for more tuning hints :) i had the same issue with my flying wing yesterday and was advised to tune with the method above
ok i will, try it the next time i will go fly . how to load a flight log with mission planner , i will try to send it to you .
can you post a log of flight with you trying to fly in FBWA ?
Have you made any attempt to tune your bird? What are your PIDs?
Try doubling your roll P and see if it makes a difference.
Have you tried autotune?
roll P done well in stabilize mode ! airplane level perfectly !
or do you think problem come from vtail output ????
same problem here.
did is possible to use my transmiter mixer and disable vtail output ????
http://diydrones.com/forum/topics/fbw-a-lethargic
I still think you need to tune your plane. Tuning is not done in Stabilize Mode, you must use FBW or AUTOTUNE.
ok but how increasse roll ???? today i test my airplane on the ground, i set max bank roll to 60 degre
i switch to fbwa
aileron works
i put my aileron stick left and hold
i bank my wing untel i have 60 degre
just a 60 degre the ailerons come in center
above 60 degre it try correct to come at 60 degre
so its means in ground the test is sucess
but when i fly , in fbwa mode in the sky , even if i put my stick full , no way to have 60 degres
soo what is the problem ?????????
no way to have 60 degres but just something like 15degres .....
