I have successfully connected the UART2 TX/RX to the UT390B laser rangefinder and sent commands to it in Arduino. But it seems misunderstood the command in Ardupilot due to baud rate or some other settings.
In Ardupilot code, I have initialized the uartC port like this:
hal.uartC->begin(115200);
and send the same initialization command using:
const uint8_t INIT_SEQUNENCE[10] = {'*','0','0','0','8','4','5','5','3','#'};
hal.uartC->write(INIT_SEQUNENCE, 10);
Is there any other source of problem I can look at?
Thanks for reading.
  • It turned out that the board and the laser range finder need common ground.
