I have upgraded to a 1 watt radio, but even with good dipole antennas I am only getting around 800 meters through trees and buildings (much more when up in the air of course). Better antennas may help, but I am considering using more power and 5 watt amplifiers appear to be possible to connect to the 3DR/Hope transmitter modules. I am concerned about transmitting and receiving with one module though. Has anyone done this before and know if the receiver circuit could be disconnected from the transmitter and bypass the 5 watt amplifier, so that it could transmit and receive half duplex with one antenna?
  • I cant help but think that this would ACE my current project :P diydrones.com/forum/topics/hoperf...
    • Yes, that would be nice. You might have to overpower the other person's transmitter. A 5 watt linear amplifier would probably work for transmitting and you could use a second module for receiving (and two antennas), but it might be worth experimenting to see if you could connect the receiver to the transmitter and have one small module.
  • More power is generally not the best solution. It will add to your problems in most cases.
    Usually antenna placement and checking RF cables for loss will help. In most systems poor quality cable and connectors will have the greatest effect.
    You can connect a 5W linear amplifier and it will work. I assuming the 5W Liner amp has a built in 'RF switch' so the transmit power doesn't reflect directly onto the receiving stage. Unless you are building a home-brew solution?
    That said using more power may give you distance when line of sight, but trees and buildings are exceptionally good attenuators at these frequencies
    FWIW, we're getting 30km comfortably with RFD 900's, with a 900MHz patch antenna on the vehicle and two OEM stick-on dipoles on the plane. I think their max power is 1W.
    5W seems overkill unless you want to go 60km+?
    21km on a bad day with RSSI's in the 90's:
    3702148448?profile=original
    • 30km is very good. I don't feel that I need 30km or 60km of range, but I am more concerned about poor reception when flying low near trees or around hills.
  • yes, it's possible to transmit at 100W too, that would be equally illegal in most countries, and equally bad for all those other devices you would interfere with.
    • True in most cases, but I have an amateur radio license and I plan on doing it legally like APRS data packets on 440mhz. Amateur handheld transceivers use 440mhz at 5 watts legally and don't interfere with anyone.
      • then you would know difference between mhz and Mhz ?
        -sorry , but you asked for it :)
        • and between Mhz and MHz...
DIY Robocars via Twitter
RT @a1k0n: @DanielChiaJH @diyrobocars @circuitlaunch Here's my car's view of that race. About 8.4 second lap times for laps 2 and 3... both…
Monday
RT @DanielChiaJH: Great racing against @a1k0n today at @diyrobocars! Pretty cool to both break sun-9s at the track today I think I got very…
Sunday
Broadcasting the @circuitlaunch race live now at https://m.twitch.tv/diyrobocars Races begin around 2:00pm PT
Saturday
RT @a1k0n: ran a huge number of hyperparameter tuning experiments yesterday; now I can train a new policy, far with better quality, in 15 m…
Saturday
RT @a1k0n: Did I get rid of hand-tuned parameters? Yes. Am I still hand-tuning more parameters? Also yes. I have a few knobs to address the…
Sep 26
RT @a1k0n: I'm not going to spoil it, but (after charging the battery) this works way better than it has any right to. The car is now faste…
Sep 26
Sep 26
Sep 24
Sep 24
Sep 24
Sep 23
Sep 22
Sep 11
Sep 10
Sep 10
Sep 10
