Hello, I'm in need to test RTL and waypoints navigation in my AC2 Xquad all stock, i can (very well under 2.0.33) loiter and "stabilize"/"simple" , what can you recommend me to do? go to another fm version? any other tips? thks
MY CONFIG:
TYPE: "QUAD X"
FIRMWARE: last .33 (AC2 directly from mission planner)
FRAME: 28mm
STOCK: all stock motors,esc,frame,prop 10x45 and weight/gravity center
SONAR: NO
TELEMETRY: NO
GPS: YES
CAMERA/FPV: NO
LIPO: 2650 3s
MAGNETOMETER: YES and enabled
PID: all default
SENSORS: closed soldered them in the board(3)
FLIGHT MODES: 3 SWITCH 1=STABILIZE, 2=SIMPLE, 3=RTL
RADIO: FUTABA 7CAP FM 72mhz
BOUGHT FROM: jdrones kit - assembled by myself
Also want to add to my previous question , this:
In mission planner, with HOLD DEFAULT ALT disbled, can anyone give me an idea of what happens if you set up a waypoint too high and then another to low in altitude.... will the quad sloooowly descend without trembling , at what descend rate? thanks ...
is there anybody here?
