Is this a good medium rig build?
Hello, I'm picking a list of parts to build an endurance big rig quadcopter. The idea is to lift a Sony A6000 for mapping (nadir, no gimbal). What are your suggestions on my build?
DAYA H4 680 (FPVmodel)
T-Motor 3508 380KV (GetFPV, but currently out of stock)
15x5 propellers (APCprop for plastics (testing), and CF from T-Motor)
Tattu 10,000mAh 6S
Hobbywing Xrotor 40A (I hear these are very dependable for use with Pixhawk)
Pixhawk 2.1 "The Cube" + GPS
3691373153?profile=original
  • Your propulsion system picks look good - i've used 3510 350kv motors (DJI 620S esc & 6S lipo) on pixhawk driven endurance multirotor carrying hard-mounted (vibration damped) Sony A6300.
    You could probably get slightly improved efficiency with smaller current oriented ESCs - you'd be fine with a high quality 20A esc based on ecalc specs. Improvements prolly marginal.
    I wasn't able to make it work but you may want to try Li-Ion batteries which will give better efficiency, if you can get away with their low C rating (current discharge max is much lower than LiPo). DIY guys built packs using 18650 cells
    Daya H4 frame looks pretty okay but I don't have any experience with it. My best frames have been ones we've built ourselves and every off-the-shelf frame we've used has its' ups and downs...
  • Hi, yes I did. As far as the frame, here's everything I've learned so far. As it comes from China you might want to sand the edges as they're rough compared to higher quality products. You might also want to rinse with water and some cleaning solution as carbon dust is still lingering. It's held up to crashes pretty well, but I've decided to put my Pixhawk inside the main frame because on the first crash I cracked a carrier board. If you crash and need replacement parts I've heard of stories where it was difficult - you might need to buy an extra frame for that. If it had square arms it would be wonderful since you have to measure that each motor mount is level with these round arms. It's not the perfect frame, but I also don't see many other options. If I needed to upgrade, I'd design my own carbon frame from here on out. Let me know if you have any other questions, I'd be happy to respond.
  • Out of interest - did you build this?
    Also looking at DAYA 680, can't find anything 'wrong' with it but chatter in general has also gone quiet about it
DIY Robocars via Twitter
Apr 27
Apr 27
RT @f1tenth: Sliding (autonomously) into the weekend like ... 🤖😎 #f1tenth #robots #AutonomousVehicles @OpenRoboticsOrg @NVIDIAEmbedded @Aut…
Apr 25
RT @chr1sa: One of the problems with autonomous car racing is that watching software drive is not a very exciting spectator sport. To help…
Apr 25
RT @SmallpixelCar: Replaced AGX Xavier with @NVIDIAEmbedded Jetson Xavier NX. Now both cars look fast and clean https://t.co/jlcoY2EjZf
Apr 25
RT @chr1sa: Yesterday we had a record number of competitors (36) in our monthly @DIYRobocars virtual autonomous car race. We kept it going…
Apr 25
Apr 16
DIY Drones via Twitter
RT @chr1sa: After more than a year of only virtual races, @DIYRobocars returns to the newly renovated @circuitlaunch on May 22 for the resu…
Apr 11
RT @DAVGtech: And now available with LiDAR 🔥 https://twitter.com/Heavy02011/status/1381137016381964293
Apr 11
RT @Heavy02011: #VirtualRaceLeague: @DIYRobocars Race #9 - #ParkingLotNerds #thunderhillracetrack, CA Join us for the next race April 24th,…
Apr 11
RT @DWalmroth: Weather's finally cooperating, looking forward to racing 1:10 scale autonomous cars outdoors again! @diyrobocars, @NVIDIAEm…
Apr 7
RT @AIDRI_: I finally succeeded in optimizing the trajectory and speed of a car on a #racetrack. Next step: implement a 2d controller and…
Apr 7
@jetdillo @circuitlaunch Actually the second *in person* event in a year. We do virtual races every month
Apr 2
Update: we're moving it back one day to Sunday (the 4th) at 11:00am instead
Apr 2
@GrantEMoe @circuitlaunch Update: we're doing it on Sunday (4th) at 11:00am instead
Apr 2
RT @chr1sa: Maybe we should have a mini @DIYRobocars race in our lower school's playground https://t.co/xLFeua1R6X
Mar 29
