Joystick on Mission Planner
Hello from Italy.
I have a question regarding Mission Planner and 3DR Radios.
I would like to use a joystick connected to the laptop which is also connected 3DR Radios, to control the movements of the camera on the drone.
If I do I enable the joystick on the MP with the channels 7 and 8,  I can use at the same time my normal radio tx to fly the drone?
Tks
  • The reason why I was looking at flying with joystick was that I thought I could get more range with the 900mhz connection to the PIXHAWK than my DX8 2.4ghz tx could get. Planning to use the myflydream for a ground station and use the 5.8ghz AV and somehow add the 900mhz patch panel to the system but not sure the tracking device can handle two patch panel antennas.
    • For the antenna tracker I'm looking for a good mechanic to install an antenna for video (5.8 GHz 11 dBi Flat Patch Antenna) and a directive for radio 3DR (440-5 Portable Hand Held Five Element Yagi)
  • Thinking about it, makes more sense to just use the joystick for the gimbal/camera operations anyway.
    • As soon as I will have prepared the ground station, I will do the tests and then write the results
  • Yes, there can be a delay in the controls. I have flown using a joystick and the 3dr radio at 57k baud, but it was difficult because it felt like there was about a tenth of a second delay. It could just be in my mind though. It may be fine for a camera gimbal. You could try increasing the baud rate to 115k, but I haven't tried it. I have been using a 3DR radio with an arducopter without telemetry (just sending the control data) at 57k baud to fly and it is updating the controls 250 times per second which is almost as fast as the servos can receive updates.
  • That is a sweet setup. I just got my joystick and DX8 both working. Was thinking about flying the plane with the joystick and using the DX8 to control the camera along with 3axis gimbal? Probably test that out soon.
    • I would use the radio (Taranis) to fly the drone and joystick to move the camera gimbal through the 3DRdatalink but I think this there will be delay in the controls because of the speed of signal transmission
DIY Robocars via Twitter
May 15
May 14
May 13
May 13
May 11
May 8
May 8
RT @SmallpixelCar: Test my car. RTK GPS worked great. Thanks @emlid for their support. https://t.co/EkQ6qmjmWR
May 8
DIY Drones via Twitter
RT @chr1sa: @kane That's @diydrones circa 2009. Still have a box of those Canon cameras that we used to strap into planes, just like this.…
May 3
RT @chr1sa: Our next @diyrobocars race is going to be outside at a real RC racetrack in Fremont on May 28. Fully autonomous racing, head-to…
Apr 30
RT @f1tenth: Our Spring 2022 F1TENTH course @PennEngineers is coming to an end with a head-to-head race as a big finale. So proud of our st…
Apr 26
RT @DanielChiaJH: I wrote a thing! Throughout the development of my @diyrobocars car I've been using @foxglovedev Studio to visualize and d…
Apr 23
RT @SmallpixelCar: My new car for high speed. Low body, everything ( @NVIDIAEmbedded Jetson Xavier NX, @emlid RTK GPS, IMC) under the deck…
Apr 23
Apr 21
RT @f1tenth: F1TENTH Race training setup @PennEngineers for our upcoming ICRA2022 @ieee_ras_icra competition. @OpenRoboticsOrg @IndyAChalle…
Apr 21
RT @fatcatFABLAB: Proud to be hosting a restarted DIY Robocars NYC Meetup April 26. Come by if you want to talk about and race self-driving…
Apr 17
