kk2.0 Quad stabilization
I'm running a kk2.0 + 4 20A Multistar ESCs + 4 EMax GF 2215-20 motors + 4 Slow Fly Props
After about a foot off the ground, the entire quadcopter starts wobbling like crazy (no auto-level) and flips soon after. Any ideas?
I've already balanced all the props and calibrated the escs.
I'll add some video if needed.
  • I am not very familiar with the KK boards, other than for using them as gimbal controllers, but there are the usual steps that we can go through to see what is going on.  I have had similar issues in the past and these are the things that were plaguing my builds:
    - motors in wrong order, or connected to signal lines in the wrong order
    - props on backwards, spinning the wrong direction
    - bad gyro or barometer...this issue has caused me a lot of grief
    if you have a video, yes, please post it so that we can better see what might be going on.
  • I'm having the same issue, and when I had my post on here I got the same amount of support that you have gotten.  Try over at RCGroups.
