I'm planning to build an octo with Pixhawk.
Motor: Tarot 5008/340Kv
ESC: Xrotor 50A
Battery: 6S 16000mah ~ 22000mah
I bought this:
http://www.goodluckbuy.com/apm2-5-2-apm2-6-pixhawk-power-module-v1-0-output-bec-3a-deans-plug.html  This have a max current of 90A.
I also looked at this:
http://www.goodluckbuy.com/120a-dual-way-ubec-distribution-board-with-v-i-sensor-for-apm-pixhawk-px4-flight-controller.html
But this is still max 120A all together. Any one have a suggestion for 300A or similar ?
OR any schematic that I could get print PCB myself ?
  • I am 100% sure what you are looking for? But maybe this is it?
    https://www.sparkfun.com/products/10644
    http://www.rc-drones.com/Vulcan-250A-Power-Distribution-Board_p_736...
    G
    • Have you looked at the Airbot module, airbotservices.com??
      Fully integrates with pixhawk, also has aux standby power for the pix and a 12v FPV output.
      Airbot Services Home page products & services description | Drones
      • Hello,
        i need an information:
        i started to build an agriculture drone with pixhawk flight controller.
        i have the problem that the standard power module included in the kit does not support my battery and motors
        I bought six motors eaglepower ea55 320kv 1300w 53A max , and a lipo battery 6S 12000mah.
        In normal conditions (50%throttle) i think they will not draw more than 25A by motor , so not more than 125A, but also in this case the standard power module cannot manage and measure this current.
        So now i am searching for a suitable power module.
        Do you have any suggestion?
        Let me know, thank you!
        Lodovico
    • I am not sitting in front of my computer right now, otherwise I would check with ecal.ch and see what the numbers are. I need exact motor and esc, which you posted, and prop size. Unless you checked yourself already. Anyhow, do you know that you don't need the power module when using the Pixhawk!? You can power it through a bec. Just saying. Of course you would lose telemetry. BUT, you can always use an external telemetry module like the FrSky stuff...
    • Musthafa, I understand that the Sparkfun is "only" rated to 180A, which is better than 90A but still falls short of being 300A. However, are you sure that you will pull more that 180A all the time? What is your AUW? Also, YOU posted a link to a power distribution board and that's why I mention the Vulcan PDB...
      Anyhow, good luck finding what you are looking for.
      • AUW is expected to be in between 6-8kg including gimbal.
        Power distribution board which I posted had pixhawk module of 120A.
    • Sparkfun can have max 180A
      Vulcan 250A is just a power distribution board, doesn't sense voltage and current through pixhawk.
      I'm looking for 300A + current module
      • hello, i have the same problem...did you find finally the power module?
DIY Robocars via Twitter
RT @masato_ka: 距離センサを3つとESP32を付けたラジコンカーをDonkeyCarライクにNNで自動走行。3層FC極小モデルをTensorFlow Lite for microcontrollerで動かしてる。機体は借り物でRumiCarって言います。Tenso…
13 hours ago
RT @SmallpixelCar: My car was able to go all the way autonomously until the crosswalk. It was only 100 yards from the target. What should b…
yesterday
Liam left a comment on Agricultural UAVs
"Hi
I'm Liam from T-MOTOR. I would like to reach out to see if there is any possibility for us to work together.
We are a propulsion system manufacturer who offers motors, propellers and ESCs for all kinds of drone applications which vary from secur…"
Wednesday
RT @SmallpixelCar: Smart move. The car used the shadow to guide it through the bridge. This was never in the training samples. But it learn…
Wednesday
RT @SmallpixelCar: Getting closer to the target. Single camera. Untrained road. https://t.co/Wsr7RwDamj
Jun 29
Richard Cox left a comment on Australia
"Anyone in the DIYDRONES Australian subgroup based in Alice Springs, NT?
I am experimenting with Ardupilot (standard Arduplane), Pixhawk 4 FC in a 4-ch
RC "AXN Floater Jet" foamy plane..."
Jun 29
Omar Sykes left a comment on Australia
"Hi everyone, I am looking for someone who is good at drone building, repair and software in Adelaide. Please give me a call on 0477 319 219."
Jun 29
RT @RoboticMasters: #donkeycar https://t.co/czuLoVRcA4
Jun 29
https://t.co/DKQbNTbz0g
Jun 29
RT @RoboticMasters: Donkey car, car car car car car car; Donkey car, car car car car car car; Donkey Car. Anyone like our tiny tiny donkey…
Jun 29
RT @SmallpixelCar: After improving DBSCAN speed, I can get 11 frame per second on @NVIDIAEmbedded Jerson Xavier MAXN mode and the autonomou…
Jun 26
RT @Heavy02011: Join us at next Virtual Race League: ⁦@diyrobocars⁩ Race #4 - Parking Lot Nerds, August 1st https://t.co/5KUpu7VGaH
Jun 25
RT @SmallpixelCar: #CUDA implementation should be easy, because most of the time is on distance calculations berween two points and if the…
Jun 25
RT @SmallpixelCar: This is the view from the car. Even my lanenet inference is fast on @NVIDIAEmbedded Jerson Xavier, DBSCAN clustering tak…
Jun 25
RT @SmallpixelCar: Ran my car in the park, with single camera and @sparkfun IMU. #TensorRT on @NVIDIAEmbedded Jetson Xavier. Lanenet one fr…
Jun 24
RT @SmallpixelCar: Making progress on drive the car autonomously in my neighborhood. This run used single camera only. No other sensors. ht…
Jun 24
