Lightened 3DR Y6
Hey guys,
Has anyone played around with lightening the arms on the 3DR Y6? My build came out a little heavy from the recommended weight so I was looking at ways to slim it down without effecting structural integrity too much.
One idea I had was to drill uniform holes in the ARMs to reduce weight. I'm not sure of the original design but the current arms are over-kill in terms of strength from what I can see.
Be interested on thoughts/experience.
Mr Gecko.
  • Sorry, I just double checked.  I trimmed 23 grams per motor from the speed control to the motor wiring including the bullets. Not distribution plugs (all soldered) is worth another 8 grams per.  I trimmed a few grams per motor off the power wires into the speed controls from the battery but they are almost full length. My SC's are about 60% down the arm and are zip tied, with wires outside.  I also trimmed a bunch more by also using all nylon hardware (except motor to arm connection).
  • I trimmed 8 oz from my 3dr hex with just good wire management.
  • I am in the process of building my 3dr y6. You say your build was a little heavy. What is the recommended weight and where did you get this spec?
    Greg
  • I don't have any insight, but agree that you could probably remove some material from the full arms.
    I just don't know how much weight you would actually save.  Most of my build weight is in the battery and motors, with the aluminum arms being a very small component.  There are, after all, only three.
  • To help with my description, I was thinking something like this: http://diydrones.com/photo/lightening-holes
