when i connect to Ardupilot with the serial monitor i received the following error:
EError: PA7 & PG1 is not reading HIGH
Press Y to continue.
I press Y and gives me the same error.
Everything is ok. Hardware led is greed. Com port has corrected settings. Switch on CLI.
Drivers ok on win7 32 bit.
Do you have any idea ?
Thanks in advance,
Gastone
That means you haven't loaded any firmware!
Please use the manual and follow the steps. You need to download the mission planner and load firmware. What you're seeing is just factory diagnostic code--there is no flight firmware loaded at the factory.
Folks, same issue here on a newly built 2560 model (jDrones sourced). Just tried APM2.0.36 and CLI ends up with the same scenario (
Error: PA6 & PK7 is not reading HIGH Press Y to continue...) as bhboyle's post. And also get the avr stkv2 timeout message when uploading as well.
I have the configuration setup for the right board, baud rate (57600, as 115K shows garbage), and cable, and latest arduino-022 version IDE. So not sure why it's having a problem uploading--time to check the code. Anyone else having luck on a ATMega2560? WIll try it on Mission Planner on windows when I can find a windows box (I'm on Linux).
I am having the exacte same problem.
I received my new kit Monday. I very carefully soldered the kit together and then went to test an upload to the board.
I always get the error below. just to be sure i connected another arduino and uploaded the blink test sketch with out issue.
I set the board type to Mega-1280. I also made sure the port was correct and i tried it with the arduino IDE version 18 and 22 all with the same results.
I do see the power LED light and there is a yellow LED next to it that is also lighted. when I send a sketch to the board i get three blinks of the TX LED.
Binary sketch size: 55264 bytes (of a 126976 byte maximum)
avrdude: stk500_recv(): programmer is not responding
this is the output of the serial monitor....
EError: PA6 & PK7 is not reading HIGH
OK: PA7
OK: PA6
OK: PB0
EError: PB4 & PH3, Also check pin PB3, PB5 is not reading HIGH
EError: PB5 & PL1, Also check pin PB4, PB6 is not reading LOW
EError: PB0 & PE6, Also check pin PH6, PB1 is not reading HIGH
OK: PB4
OK: PB5
OK: PC0
EError: PC1 & PF1 is not reading HIGH
OK: PC2
OK: PC3
EError: PC4 & PF4 is not reading LOW
EError: PC5 & PF5 is not reading HIGH
OK: PC6
EError: PC7 & PF7, Also check pin VCC next to it is not reading HIGH
EError: PC0 & PF0, Also check pin PG1 is not reading HIGH
OK: PF1
EError: PC2 & PF2 is not reading HIGH
OK: PF3
OK: PF4
OK: PF5
EError: PC6 & PF6 is not reading HIGH
OK: PF7
EError: PD0 & PK3, Also check pin PL7, PD1 is not reading LOW
OK: PD1
EError: PD4 & PK1, Also check pin PD3, PD5 is not reading LOW
OK: PD0
EError: PD1 & PK4, Also check pin PD0, PD2 is not reading LOW
OK: PD4
OK: PE3
EError: PE6 & PB0, Also check pin PE5, PE7 is not reading HIGH
OK: PE7
EError: PE3 & PH1, Also check pin PE2, PE4 is not reading HIGH
OK: PE6
EError: PE7 & PH6, Also check pin PE6, VCC is not reading HIGH
PLEASE HELP!!
thanks for your reply. This is what i did. I assembled and soldered the full kit and everything seems ok. Led green on board and blu led on. I downloaded arduino .0022 (last version) install libraries and sketch for piratesng firmware. I modified the config.h for my application and when i compile everything is ok.
When i press "UPLOAD" it gave to me the SYNC ERROR..cannot find the board. (i selected the correct board and com).
The hardware i think is working good because when i press the "boot" function it boot and all led are ok.
Does i need to load something before place the piratesng code?
If you can help me i will be very grateful because it's my first experience with arducopter platform.
I'm trying to find a person that can explain me some things...also if i have to paid something for lesson..not a problem...but i need it.
Thanks in advance and have a nice day.
