Hey everyone!
I am a relative noob to the RC world, but lately I have a reason to dive in head first...
I have a small company that designs & builds various electrical / alt power gear, much of it oriented around HAM radio and portable / emergency power & communications.
We have been making progress on an R&D project that just won't die... we keep getting closer to something that might work.  ;-)
3691266336?profile=original
The goal of the project:
A small, collapsible flying platform that can lift a communications antenna about 30' off of the ground and hold it fairly steady for anywhere from a few minutes to a few hours.
3691266441?profile=original
The antenna is a flexible whip, about 20" long and weighing 34 grams (not pictured).
Power for the system comes from a DC source on the ground.
Control of the system is limited to throttle only.
Weight of the tether (DC power, signal for throttle, and antenna feedline) at max (30') height is 500 - 700 grams.
Weight of the air frame (motors,chassis, flight control, etc. is about 300 grams.
Currently building around Black Widow 2204 motors (with ESC built in).
Using Naze32 rev5 FC with 5030 props.
Primary construction of chassis is 3D printed ABS.
A few questions:
  Do I need to use a small buck converter to deliver 5 volts to the Naze?  Information I am finding online is not clear... remember I am not running a BEC
  What is a good way to control motor speed... use a servo tester as throttle?  A PWM speed controller? Remember this control is on the ground, hard wired up to the platform.
  Any thoughts on the Naze being able to maintain level hover despite wind or movement of the operator on the ground?  We are not running a GPS and don't want to.
Thanks in advance for your thoughts!
  • Hi Bill,
    you should get real, your project is generally down.
    To stabilize your drone, airframe, you should attach antenna to point downward.
    So hot air balloon or kite is a nicer solution to your problem.
    BTW
    3D printed ABS airframe is heavy, so people generally opt for laser cut carbon
    Hot air baloon
    • Hi Bill,
      Antenna needs to point up.  Pointing down causes issues with bringing the system down to operator and with tether management.  A capable FCU can easily handle the antenna up.
      Repeating myself.  Balloon or kite is the OLD solution.  Not feasible with this project.
      BTW
      I am not flying batteries or a receiver.
        Power is essentially unlimited.  3D printed ABS is strong.
      Hot air baloon
      Nope.
      • The original questions I am seeking help with:
        • Here is a link to the NAZE32 manual.
        • The Naze32 must be powered by a regulated 5 Volt supply.
          You may use a linear regulator or a buck converter or a buck/boost converter.
          It would be advisable to add at least a 1000 uF , Micro Farad, capacitor in parallel with a 0.1 uF ceramic capacitor on the Naze32 board's power input because the power supply leads are so long and they are susceptible noise.
          It would also be more preferable to use a regulator or buck converter on the copter [with capacitors on both sides of the regulator/boost converter]  rather than having the supply regulation on the ground.
          • I edited my above comment, but I don't know if it saved. So I'm re-posting my edit.
            The above was just for powering the naze32 board. not the ESC's
            Generally one should add about 220 Micro Farads of low ESR capacitance for every addition 4 inches of additional power lead lenght for ESC's.
            For 30 feet:  That would be about an addition 20000 Micro Farads for each ESC to cancel out the inductive effects of the power supply leads.
            I can find a good discussion link about this from Rcgroups tomorrow.
  • Hello. Why don't you use a Helium baloon instead?
    You will need to output more than throttle only. I would highly recommend you to use either a radiocommand, or at least to add electronic that transmit all necessary input servo signal to the flight controller. Without gps you will kot keep ground position, at least if you have RC control you can pilot your copter.
    • I mean that the flight controler does need more than throttle input. Without any signal on Roll/Pitch/Yaw/Aux functions I think that it may not spin the props at all.
      • Interesting... I have only run the prototype on the bench, using Baseflight to test the motors.  I hope / assume that if I give the FC power and a connection to the motors/ESC that it will begin working to hold pitch & roll?  No?
        This is why I posted, I think.  THANKS for helping me identify weakness in the concept...
        • So how do I test if the FC will take over?  Say I have the prototype on the bench, and am using a servo tester as a throttle.  Motors are spinning, props are attached (I know, I know).  Unit is in a safe place for testing.  What causes the FC to begin flight control?
          Sorry for being such a noob...
DIY Robocars via Twitter
RT @TinkerGen_: "The Tinkergen MARK ($199) is my new favorite starter robocar. It’s got everything — computer vision, deep learning, sensor…
Monday
Monday
RT @roboton_io: Join our FREE Sumo Competition 🤖🏆 👉 https://roboton.io/ranking/vsc2020 #sumo #robot #edtech #competition #games4ed https://t.co/WOx…
Nov 16
DIY Drones via Twitter
First impressions of Tinkergen MARK robocar https://ift.tt/36IeZHc
Nov 16
Our review of the @TinkerGen_ MARK robocar, which is the best on the market right now https://diyrobocars.com/2020/11/15/first-impressions-of-tinkergen-mark-robocar/ https://t.co/ENIlU5SfZ2
Nov 15
RT @Ingmar_Stapel: I have now explained the OpenBot project in great detail on my blog with 12 articles step by step. I hope you enjoy read…
Nov 15
RT @DAVGtech: This is a must attend. Click the link, follow link to read the story, sign up. #chaos2020 #digitalconnection #digitalworld ht…
Nov 15
RT @a1k0n: Got a new chassis for outdoor races (hobbyking Quantum Vandal) but I totally didn't expect that it might cause problems for my g…
Nov 11
First impressions of the Intel OpenBot https://ift.tt/36qkVV4
Nov 10
Nov 9
Excellent use of cardboard instead of 3D printing! https://twitter.com/Ingmar_Stapel/status/1324960595318333441
Nov 7
RT @chr1sa: We've got a record 50 teams competing in this month's @DIYRobocars @donkey_car virtual AI car race. Starting today at 10:00am…
Nov 7
Nov 6
RT @a1k0n: Car's view, using a fisheye camera. The ceiling light tracking algorithm gave me some ideas to improve ConeSLAM, and having grou…
Nov 5
RT @a1k0n: To get ground truth I measured the rug, found the pixel coordinates of its corners, calibrated my phone camera with my standard…
Nov 5
RT @a1k0n: @DIYRobocars is back in December, but outside. Time to reinvestigate ConeSLAM! I rigged up a quick and dirty ground-truth captur…
Nov 5
