      Hi guys,
      I have access to the l1/l2 tersus boards, and have been evaluating them recently.
      the ardupilot driver ive been working on can be found here
      https://github.com/meee1/ardupilot/commit/267dd2afae1a81fa3a38ca536...
      At this stage i've have just been car testing, as the weather here is bad at the moment.
      logs here
      http://vps.oborne.me/rtk/Tersus%2023-5-2016/
      so far everything looks as it should, I just need to put it in a plane and do an actual flight test.
      ive managed full rtk fixed without any problems, feeding in rtcm 1005, 1004, 1012
      Michael
      AP_GPS_NOVA: support tersus/novatel/comnav gps · meee1/ardupilot@267dd2a
      Contribute to meee1/ardupilot development by creating an account on GitHub.
      • Thanks Michael for sharing this!
  • So what is the status of this system? Are you logging the positional data for post processing? Have you made any changes since you last posted? I noticed the range is currently 1 km is this due only to the radio being used? Could you increase the range if you use higher power radios?
    Thanks,
    Robert
    • the radio distance is highly dependent with the RF radio power. if you use some high end radio, and tune the power to 10W, then you can go 5-10km+ usually.
    • Yes, I'd like to know is radio interchangeable with RFD900??
      • yes, its uart interface. can interchangeable with any radio with UART interface.
    • I want to know it also....
  • I didn't mean to mislead, there is no need to use the RINEX format for the actual real-time logging. A more efficient binary format would probably make more sense for the actual logging. As long as this format can then be converted to RINEX for post processing.
    Robert
    • Of course that binary format is much less memory consumer, this is how all the professional GPS manufacturers do.
  • @Tazmoe,
    I am approached by manufacturers of high-precision Ublox chip based GPS units, claiming 5-10 metres accuracy due to ionospheric error.
    If remote service can postprocess GCS raw data to provide geodesy grade
    1cm accuracy for the ground based station so why the number of GCS is so limited and not grows into global high-aacuracy GCS network
    and placing raw data output GPS unit at geodesy grade GCS point, one could
    build high-accuracy RTKLib based Rover.
    Basing on your experience with RTK modules, tell me if GCS and Rover should not generate 3DFix based on the same constallation and HDOP and PDOP should not match to get GCS and Rover offsets to match either.
DIY Robocars via Twitter
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
Monday
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Nov 26
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Nov 25
@gclue_akira CC @NVIDIAEmbedded
Nov 23
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9
RT @JoeSpeeds: Sat Nov 6 Virtual DonkeyCar (and other cars, too) Race. So bring any car? @diyrobocars @IndyAChallenge https://t.co/nZQTff5…
Oct 31
RT @JoeSpeeds: @chr1sa awesomely scary to see in person as our $1M robot almost clipped the walls as it spun at 140mph. But it was also awe…
Oct 29
RT @chr1sa: Hey, @a1k0n's amazing "localize by the ceiling lights" @diyrobocars made @hackaday! It's consistently been the fastest in our…
Oct 25
RT @IMS: It’s only fitting that @BostonDynamics Spot is waving the green flag for today’s @IndyAChallenge! Watch LIVE 👉 https://t.co/NtKnO…
Oct 23
RT @IndyAChallenge: Congratulations to @TU_Muenchen the winners of the historic @IndyAChallenge and $1M. The first autonomous racecar comp…
Oct 23
RT @JoeSpeeds: 🏎@TU_Muenchen #ROS 2 @EclipseCyclone #DDS #Zenoh 137mph. Saturday 10am EDT @IndyAChallenge @Twitch http://indyautonomouschallenge.com/stream
Oct 23
RT @DAVGtech: Another incident: https://t.co/G1pTxQug6B
Oct 23
