Mapping plane frame
I used to fly with nex5 on x-uav talon and canon s100 on skywalker 1900, but as i decided to renew airframes, found out that none of them available on ghe market.
What frames are new on the market instead of talon and skywaker? With wide fuselage and 45-65 dm3 wing area? Can't find anything in stocks...
      • Jim, I trigger the QX1 by using an 11 pin micro usb connector and connecting it to Pixhawk's Aux connector. I get the pre wired 11 pin micro USB from a $9 clone of the VPR1 trigger.  The trigger is available at here. I cut and strip the wire and keep the end with the usb. Next step is to figure out of the 3 wires which one is ground and which trigger focus and shutter. Plug the wire in the camera and take a volt meter set to DC. There will be two wires that measure 3.3v and the other will be ground. When I find the two wires that have 3.3v I splice them together and put them in a servo connector. The 3.3v goes to signal and ground goes to ground.
        Since the camera triggers when you ground the 3.3v you need to change a parameter in Ardupilot. From mission planner change CAM_RELAY_ON: Relay ON value to 0 which will cause Pixhawk to ground the 3.3v. Since shutter and focus are wired together the camera will do both and snap a picture.
        This works on many of the Sony cameras but you must verify the VPR1 will work with your model. It does work with QX1.
        Later I want to have the focus on a different relay so I can have it focus and hold once in the air flying. Personally this works so much better than Canon's with CHDK. I can get shutter rates at under 1 per second. With my A6000 I get a picture every .74 seconds.
        • Rob,
          Superb, thanks very much.
    • Did you think about the Sky Cruise 2400 ?
      I own this one, and i am verry impressed on it. I would prefer this one...
      https://www.centuryuk.com/RC-Planes/Gliders/Top-Rc-Hobby-Sky-Cruise
      https://www.google.de/search?q=skycruise+2400&source=lnms&t...
      Century UK LTD, Home to the latest in Radio Control Technology
      Century UK Home to all of your modelling needs, from Radio Control Planes and Helicopters to Radio Control Cars and Premium Line Model Boats.
  • 300km
    Try http://www.fpvmodel.com/new-2015-skywalker-1830-1830mm-fpv-plane_g9...
    I'm setting up a New 2015 Skywalker 1830mm (as above) for mapping and was planning on having a  servo roll only gimbal mounted instead of the removable nose section.
    @ Iskess are you able to share some photos of your NEX and roll gimbal? Is the camera top forward? Does it fit within the fuse?
    • Btw, aren't you afraid of steep stall or spin? In the nose the cam will be killed by battery almost 100%...
      • 300km
        You're right, that position offers no protection.
        When the camera is worth 5 times more than the airframe it would be worth finding a position that offered some protection.
    • Can you measure fuselage width?
      • 300km
        The widest point of the cut out (the plywood framing) is 115mm.
        The internal space in the nose is about 100mm wide.
        (A NEX5 is 110mm wide)
        I've just noticed the removable fueslage side doors under the wing. That would allow a camera to fit in the main bay and sitck out the sides a bit if needed. That would offer pretty good protection. But it's quite high up which would mean a big hole in the bottom to give it a clear view down, especially with a roll gimbal.
      • Here you go.
        https://storage.ning.com/topology/rest/1.0/file/get/3702743282?profile=original
