Massive instability on take off.
Hi guys, a newly rebuilt quad of mine has some sizeable wobble which mean I can't really take off. I thought it could prop wash potentially, so the solution could be to just punch it into the air, but Im a little scared to do that given the cost of the equipment onboard. Here is a video of what happens every time I take off. Sorry for the vert. recording.
https://www.youtube.com/watch?v=JjCXkwWefZs
  • So it turns out you guys were right. It was set up as a plus config not an x config. I don't know how that happened. Now it flies fine in stability mode, but when I switch it to loiter, nothing happens, its like it is still in stability mode. I guess it needs a tune.
  • Brothers, can anyone help?
    The quad is setup up properly, its motors and props are in the right configuration, I had some issue tuning the ESCs, but I think they are tuned, I calibrate the compass and the accelerometers, Im just not sure where to go from here.
      Are you trying fly it in + when it should be X ??? What PIDs are you using???
      Please add a log file, its impossible to tell from a video what is wrong.
      • Was gonna say the same. It looks sooo much like a 45 degrees off error, ie, an X copter configured as a + or opposite.
        OP please check that. And you can remove propellers and check that only the front one motor (+) or both front motors (X) speed up as you "fly" it held in your hands dip the nose. Similarly with back, left and right.
        Regards
        Soren
        • Here is the weird thing, the thing has been calibrated. Im pretty sure it is in the X configuration. When I rock the thing forward, left, right and backwards with the directional control on the remote, it rocks on its landing gear, exactly the way it is supposed to.
DIY Robocars via Twitter
RT @SmallpixelCar: First time at @wsraceways. After tuning @HokuyoUsa lidar signal and camera sensor on @NVIDIAEmbedded, my car was able to…
Sunday
RT @breadcentric: The handy bit about racing with self-driving cars is that one can type while the car is racing. Report from #AWSDeepRacer…
Friday
RT @chr1sa: Our Bay Area @DIYRobocars meetup is now at 2,700 members. Next in-person events (in Oakland) are training day on July 17 and…
Friday
Videos from the ICRA autonomous racing workshop are now available: https://linklab-uva.github.io/icra-autonomous-racing/
Jun 10
RT @SmallpixelCar: Prepared race track for Warm Spring Raceways @wsraceways and looking forward to test my new car at RAMS RC @ramsaicar fa…
Jun 6
RT @f1tenth: Trying out some nasty blocking maneuvers 🏎️🤖 #f1tenth #autonomousracing https://t.co/nMTstsaogM
Jun 5
May 27
RT @araffin2: I will talk this Saturday from 18:00 to 19:00 Paris time for the @diyrobocars community about learning to race in hours using…
May 27
RT @a1k0n: Luckily the infeasible hairpin problem was easily reproducible in simulation and I could test the fix before bringing the car ba…
May 26
RT @a1k0n: Another problem was that I was over-constraining the car's allowed accelerations, so it didn't think it could turn as tight as i…
May 26
RT @a1k0n: Breaking the map up into two halves worked, but I had to be more careful about separating the inner track from outer. There's se…
May 26
RT @a1k0n: Here's a datalog for my fastest lap of the day. Lap timer is tiny window lower-left. https://t.co/myrlWWrKUY
May 26
May 26
RT @a1k0n: Here was my car's POV. Man this track is confusing in first-person! After the incident my camera was all scuffed up and I was af…
May 23
RT @circuitlaunch: Loved seeing so many familiar (masked) faces at Circuit Launch today for our first in person @diyrobocars in over a year…
May 22
RT @circuitlaunch: Last but not least, mystery guest @BostonDynamics Spot took to the track @diyrobocars He enjoyed the #brazilianbbq too 😂…
May 22
