MediaTek 3329 - connection via Xbee
Hello,
I have a problem with MediaTek 3329 and Baud rate:
I bought this GPS here (Diydrones) and I loaded a new firmware (from the diydrones). If I connect this GPS through FTDI cable and set 38 400 baud so everything is OK (in HK's Ground Control Station). But If I connect this GPS to the xbee (I use XtreamBee board) so I have not right NMEA data. The baud rate of the xbees is set to 38 400.
Can you help me?
Thank you
Jakub
  • Jakub,
    I have the same MediaTek MT3329 GPS module and i am trying to update the firmware/see what firmware does it have using Mini GPS software.I tried to connect with Prolific USB-t0-Serial cable not the FTDI.It did not work.Can you tell me what type of FTDI cable did u used?. Btw my GPS modules status LED is always on..Any idea what does that mean..I was thinking that it should blink till it's get satellite lock and goes solid.Any idea?
    Thx
    I'm afraid I don't understand the question. What do you mean "connect GPS to xbee"? Are you using APM boards and code? If not, you'll have to explain what you are using.
