Minim Osd
Hi all,
I've just been doing some tests with the Minim Osd and I must say it's great. One thing which is bothering me though is the positioning of the characters on the screen. I am transmitting using a fatshark 5.8 Ghz transmitter to my fat shark goggles. I am then routing from the goggles to a monitor. In both the fatshark goggles and the monitor, the bottom most characters are cut off at the bottom of the screen. At first I thought it was defaulting to NTSC so I soldered the PAL jumper on the back of the board, but there was no change. The camera is PAL and the goggles are receiving and routing out a PAL image. I know there is no configurator at the moment but perhaps there is a way to adjust the code ? Any suggestions ?
Regards
Eoin
  • Also experienced the same problem.
  • hi, im thinking of getting 1 of these osd's, what info is it displaying on the screen?, is it easy to setup?, any programming requied to set it up?
