OK all...I'm sure this has probably been addressed previously but I haven't found it. I'm having issues with the MinimOSD (latest firmware and all) and a GoPro Hero 3 camera (latest firmware as well). Here's the situation:
- Had OSD working properly with Hobby King camera prior to buying the GoPro
- I've now installed the GoPro but I get no video from it. I can see the OSD information but no video from the GoPro.
- I am using a proper USB to composite cable for the Hero 3 (i.e. the 10-pin mini USB)
- I can get video out of the GoPro if I go directly from camera to a video display device such as a computer (in other words...I've verified that the USB cable works properly)
- I've updated the OSD firmware and character set a couple times now...no change.
- I'm powering the OSD and transmitter from a dedicated power supply at exactly 12 volts
- I'm not sending power to the GoPro but I am sharing the ground with the OSD and transmitter
- I've tried bypassing the transmitter and sending OSD and video directly to the display device via hardwire connection...no change.
- I've turned on the Hero 3's wifi while connected to the OSD just to see if I can get video from the camera that way. Video feed over wifi is successful.
- Here's the most interesting symptom...If I slowly decrease the voltage I provide the OSD from 12 volts down to ~9.5 volts, I can get the camera video to sporadically appear. Sometimes it takes the place of the OSD overlay and sometimes it is combined with the OSD overlay...just depends on the voltage I send the OSD. So....it's acting like the OSD is just plain overpowering the video signal from the camera.
- The OSD and the camera are both set to NTSC video standard
So there's my situation. I've come to the end of ideas on where to go from here. Any help or guidance would be greatly appreciated.
Cheers,
Wayne
Wayne, I had the same issue and I discovered that the gopro company is updating all cameras and disconecting the usb port; so if u did the update, I'm sorry, but probably you loose your cam for transmission, like me.
I complained to gopro company and explained that it's stupid and bla bla bla....anyway, the gopro technicians didn't know why it happened. Two days ago I bought a new gopro4 black and I didn't updating it and it's working and I didn't replace any cable or transmiter....I hope that 3DR can help us telling withe gopro to reverting this issue..
I'll open a new topic about it.
I hope I could help you.
I have the same problem with my hero 3+ I purchased from 3drobotics. I have read through the responses and I have verified all the connections without the minimum osd and also cant get any video. I never connected any cables from the camera that was not checked and rechecked based on the drawing provided from 3dr. I am unable to get any kind of help from them.( other than they sent me the cable drawing - thanks - ) I never connected the camera to anything before I received the drawing.. does anyone have any idea or should I just send it back. Oh yea the OSD board works fine with the Sony camera. I did notice that it seems to get hot when the gopro is connected. ( warm when the Sony is connected ) !! thanks for everyone's help..
keith
Wayne, were you able to resolve your issue? Have you tried using a pull-up resistor on the cable to the gopro?
